Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Circuit Studio layer Colors
  • Locked Locked
  • Subscribers 87 subscribers
  • Views 862 views
  • cs
  • layers
grahamsutter
grahamsutter over 9 years ago
Hi
Just trying to do the basics: set layer colors - top red, bottom blue, both solid. Using Filter and Object Inspector, then Home/Select All. Any net that has traces on both layers has odd artifacts: red top layer trace has blue specks at high zoom which take over at low zoom and make those top layer traces blue.
What setting have I missed?
Just by way of context, I have 15 years experience with Protel.
Thanks for any pointers. Graham.
  • e14softwareteam
    0 e14softwareteam over 9 years ago
    Hi Graham,
    I will submit this to the developers and will let you know what they say.
    Tony
  • e14softwareteam
    From the developers:
    Can he provide a screenshot? First thought would be graphics card but if he has a copy of AD installed that he is comparing to then the result should be exactly the same because it uses the same graphics\drawing engine. If it's just on the the objects when they are selected and they look like a checker board when zooming maybe the Board Insight Color Override settings are getting changed inadvertently (these exist in AD but not CS). One way to find out is to;
    1) close CS
    2) run Add\Remove Programs>>CircuitStudio
    3) select the "Remove Preferences" option from the unistaller.
    This will set all preference back to defaults.
  • e14softwareteam
    Hi Graham,
    Just following up.  Did you send us the screenshot?
    Tony
