Can't hide the BiDirectional IEEE symbol of a pin in CircuitStudio
see video:
see video:
I did try that, and it does remove the arrows. Actually this is how these parts were originally configured (i.e. with all their pins configured as "passive")
However, when you compile a project containing components that have tons of passive pins, you will end up with a whack-load of warnings telling you a net has a Input Pin without a driving source, as well as other errors related to nets connecting passive pins to other types of pins.
Changing the electrical type of a pin is not an acceptable workaround for this display issue
So, is there a way to hide these symbols without changing the pin's electrical type?
You also can just disable this warning if you do not care about it.
Go to Tab Error Reporting in the Project Options and in the section Violations Associated with Nets set Nets with No Driving Source to "No Report".
Then you can leave all pins passive.
