Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Importing DXF Alters Board Shape
  • Locked Locked
  • Replies 12 replies
  • Subscribers 89 subscribers
  • Views 2724 views
  • importing
  • dxf
  • dxf import
bugrobotics
bugrobotics over 7 years ago
Importing a DXF for use as a custom polygon pour is altering my board shape (making it smaller).  It isn't changing the outline layer.  Any ideas?
Some pics:
Before DXF Import
After DXF Import
  • e14softwareuk
    e14softwareuk over 7 years ago in reply to bugrobotics +1
    Thanks for the file. I have managed to reproduce the issue as follows. Started a new PCB, defined a small 3D board outline and then imported the DXF file onto the Top Layer. The DXF had a large X,Y offset…
  • e14softwareuk
    I didn't manage to reproduce that behaviour but I have raised a ticket with Altium to take a look as this does seem like a bug.
  • bugrobotics
    0 bugrobotics over 7 years ago in reply to e14softwareuk
    First off, thanks for sending this in, responding quickly and creating the article.  Truly appreciate the work.
    Although I can see where you all are going with the workaround (and I've used that in the past) I would recommend a different workflow.  Instead of reinstating the board shape after DXF imports I would urge users to add additional PCB files to their projects to handle all of the DXF manipulation.  That has worked wonderfully and allows a "sandbox" that does not influence the main PCB document, especially when you are doing many DXF imports to define custom polygon pours, logos, custom text, etc.
  • bugrobotics
    0 bugrobotics over 7 years ago in reply to bugrobotics
    Here is a cruddy video showing my workflow as well as some general tips to get DXFs imported and manipulated.
