Altium CircuitStudio
  • Altium CircuitStudio
Altium CircuitStudio Forum Corrupt text is now making job output unusable !
  • Locked Locked
  • Subscribers 89 subscribers
  • Views 989 views
nhee
nhee over 4 years ago
When I do a final output print set, several of the pages have the "invisible" text I mentioned in another post, spread over the sheet.  This renders it unusable.
I can step through the sheets one at a time and this text does not appear anywhere.
If I select areas where the text appears, nothing is selected.  If I select all, same thing ... nothing is selected in the areas of the corrupt text.
All I can say is ... HELP !
  • nhee
    0 nhee over 4 years ago
    Partial Solution
    I discovered that a select box vs "select all" discriminate in different ways, to my advantage.
    1.  zoom out to show several times your sheet size
    2. select the entire sheet with a "selection box"
    3. move this selection upwards one full sheet height plus a little more
    4. perform a "select all"
    5. perform a deselect inside
    6. select the entire sheet with a "selection box"
    7. IMPORTANT - DON'T DO ANYTHING ELSE before hitting your delete key
    The cr-p was not selected in step 2 but was selected in step 6, allowing us to separate the cr-p from the good stuff and allowing deletion.
    WHAT A PITA !!  Hope this helps someone else in the same predicament.
    You will need to set your origin again for the board.
