Cypress
  • Cypress
Cypress
Forum USB TIme out error (Python | PSoC 5) Please help me to sort this out. Why its coming?
Join Cypress to participate - click to join for free!
  • Subscribers 8 subscribers
  • Views 1381 views
  • python
  • psoc5
  • usb
  • cy8ckit-059
  • cypress_semiconductor
  • USBFS
Shuvra1
Shuvra1 over 4 years ago
I am having all code with me (https://drive.google.com/drive/folders/1hKyy2O2HLyh9o4wxKsPFoyXOMyaorkv7) ---- Kindly help me to sort this out.
https://www.duo.uio.no/bitstream/handle/10852/82665/5/Olav-Bjerke---masteroppgave.pdf . Getting USB Time out error while replicating this into CY8CKIT-059image
    0 shabaz over 4 years ago
    You might need to troubleshoot further. From the screenshot it's not clear if this is an issue with the code on the PSoC or your setup on the PC. There's quite a few layers of interaction between the top-level Python code, down to the interaction with the microcontroller. If you're using code copied from that PDF, then it's a bit unreasonable to expect it to work without some changes, because the student will have just taken a snapshot of code for the purpose of completing the essay, and not necessarily at the same time for the different elements of that project.
    As it is, it's impossible for anyone else to identify the problem for you without running the code themselves (which is a bit much to ask for - who is going to install all this on a PSoC and their PC? You need to troubleshoot further and narrow down the problem and point the reader to your theory of where the problem is, and where you need help.
  • Shuvra1
    0 Shuvra1 over 4 years ago in reply to shabaz
    Dear sir, From a humanitarian Point of view. Please help. It's a master-level project. You might help me in this regard. Actually that code was downloaded from github . drive.google.com/.../1zO6hu0rrKnJIH_8sASo8SRnllUYfMe4Q
  • Shuvra1
    pyUSB --USB Time out error --- How to resolve the time out error ---Can it be replicated with same logic based on sending command & getting datas
