IQD Frequency Products
  • IQD Frequency Products
Blog Disciplined oscillator offers extended holdover
Join IQD Frequency Products to participate - click to join for free!
  • Author Author: IQD-Frequency
  • Date Created: 17 Sep 2024 11:57 AM Date Created
  • Views 1323 views
  • Comments 11 comments
  • oscillator
  • timing
  • quartz
  • frequency
IQD-Frequency
IQD-Frequency
17 Sep 2024
The IQCM-200 is a disciplined OCXO, incorporating sync to a 1 PPS (pulse per second) input as well as a 1 PPS output. Its exceptional holdover stability and accuracy makes this particular product a superlative Disciplined OCXO.
The IQCM-200 is part of a series of disciplined OCXOs available from IQD. This particular model is the smallest sized OCXO capable of achieving a holdover capability of 1.5µs over 24 hours meaning you can rest assured your devices can continue to function with incredible accuracy during a holdover period.
This ‘best in class’ holdover stability of up to 1.5 μs over 24 hours across 0 – 60 °C, and 25 µs typical in 10 days at 25 ±2 °C is achieved using an adaptive algorithm. Internal parameters of the algorithm, including maintenance alarms and message functions are available to the user via a serial interface. A Frequency stability better than ±0.02 ppb is achievable.
Extensive in-house testing of the ICQM-200 has been carried out by our engineers here at our laboratory in the UK. In these controlled tests the holdover achieved by the IQCM-200 after 10 days was a very impressive 25.5 μs, ideal if your application requires a longer holdover than 24 hours. Tests also concluded ADEV figures as 2.2E-12 @ τ = 1 s.
Due to its exceptional holdover times, this product is ideal for applications that require an accurate time reference, Telecoms LTE and 5G timing, and PTP GM clocks with the required IEEE 1588 holdover support, and within White Rabbit applications. This particular model will be an excellent asset to power sector products which require increased holdover times due to the emerging changes and requirements within this sector. The IQCM-200 is compliant with MiFID II.
An IQCM Evaluation Board is also available for this series (contact . Details on all the tests carried out including the 10 day holdover can be found in the IQCM-200 handbook. For your copy please contact sales and support teams at any time.
Find IQCM-200 on Farnell
    shabaz over 1 year ago
    Something weird going on, think it needs Dudley  and cstanton  expertise.
    The URL is broken, but it was definitely working before.
    This works (if you prepend https:// to it):
    uk.farnell.com/c/crystals-oscillators/oscillators/oven-controlled-ocxo-oscillators?st=IQCM-200
    However, this one fails, and gives a 403 response:
    uk.farnell.com/w/c/crystals-oscillators/oscillators/oven-controlled-ocxo-oscillators?CMP=e14c-direct-ugc&st=IQCM-200&COM=e14c-direct-ugc&osetc=e14c-direct-ugc&COM=e14c-direct-ugc&osetc=e14c-direct-ugc
    Error screenshot (it's not a PC issue, I see the same thing on my mobile phone, and most users don't wish to clear cookies : )
  • cstanton
    cstanton over 1 year ago in reply to shabaz
    That's a whacky mess, what is the online store up to now?
    shabaz over 1 year ago in reply to cstanton
    I don't know, how can you be sure it's an online store issue? I think this site modifies URLs to indicate the origin was from element14, and to me it looks like something has gone wrong with that code, it's appended e14c-direct-ugc multiple times to the URL.
