IQD Frequency Products
  • IQD Frequency Products
Blog Disciplined oscillator offers extended holdover
Join IQD Frequency Products to participate - click to join for free!
  • Author Author: IQD-Frequency
  • Date Created: 17 Sep 2024 11:57 AM Date Created
  • Views 1380 views
  • Comments 11 comments
  • oscillator
  • timing
  • quartz
  • frequency
IQD-Frequency
IQD-Frequency
17 Sep 2024
The IQCM-200 is a disciplined OCXO, incorporating sync to a 1 PPS (pulse per second) input as well as a 1 PPS output. Its exceptional holdover stability and accuracy makes this particular product a superlative Disciplined OCXO.
The IQCM-200 is part of a series of disciplined OCXOs available from IQD. This particular model is the smallest sized OCXO capable of achieving a holdover capability of 1.5µs over 24 hours meaning you can rest assured your devices can continue to function with incredible accuracy during a holdover period.
This ‘best in class’ holdover stability of up to 1.5 μs over 24 hours across 0 – 60 °C, and 25 µs typical in 10 days at 25 ±2 °C is achieved using an adaptive algorithm. Internal parameters of the algorithm, including maintenance alarms and message functions are available to the user via a serial interface. A Frequency stability better than ±0.02 ppb is achievable.
Extensive in-house testing of the ICQM-200 has been carried out by our engineers here at our laboratory in the UK. In these controlled tests the holdover achieved by the IQCM-200 after 10 days was a very impressive 25.5 μs, ideal if your application requires a longer holdover than 24 hours. Tests also concluded ADEV figures as 2.2E-12 @ τ = 1 s.
Due to its exceptional holdover times, this product is ideal for applications that require an accurate time reference, Telecoms LTE and 5G timing, and PTP GM clocks with the required IEEE 1588 holdover support, and within White Rabbit applications. This particular model will be an excellent asset to power sector products which require increased holdover times due to the emerging changes and requirements within this sector. The IQCM-200 is compliant with MiFID II.
An IQCM Evaluation Board is also available for this series (contact . Details on all the tests carried out including the 10 day holdover can be found in the IQCM-200 handbook. For your copy please contact sales and support teams at any time.
Find IQCM-200 on Farnell
  • michaelkellett
    michaelkellett over 1 year ago
    The link doesn't get you to a product listing Frowning2
    MK
    shabaz over 1 year ago in reply to michaelkellett
    It's been corrected now, but the 1-off price makes it hard to evaluate; think this product needs some reviews/RoadTest to learn more.
    https://uk.farnell.com/w/c/crystals-oscillators/oscillators/oven-controlled-ocxo-oscillators?CMP=e14c-direct-ugc&st=IQCM-200&COM=e14c-direct-ugc&osetc=e14c-direct-ugc
  • michaelkellett
    michaelkellett over 1 year ago in reply to shabaz
    I wonder how many E14 members have the gear to evaluate it. I run a 10MHz GPS disciplined local frequency standard but it comes form a box which retails at less than15% of the price of the IQCM-200 !
    None the less - I would be happy to have a play with one ....
    MK
  • michaelkellett
    MK
  • Nick
    Nick over 1 year ago in reply to michaelkellett
    Hi Michael, the quickest way to test this might be with one of these, be sure to stipulate whether you want the GNSS receiver with it or not. as this affects the price.
    https://portal.iqdfrequencyproducts.com/products/details/iqcm-evboard.pdf
    As for cheaper options, your right there are many other ways to achieve a 10MHz GPS disciplined reference frequency. Where this product stands out is when that GPS signal is lost, this product will continue to generate the 1PPS (and 10MHz), and continue to be within 1.5us of the original 1PPS phase (with a logarithmic decay here so a lot better for shorter time periods)
  • michaelkellett
    michaelkellett over 1 year ago in reply to Nick
    Hello Nick, thanks for the additional information.
    I wasn't suggesting that the IQCM-200 was overpriced - merely that it would be hard to judge its performance without something rather better than I have available, and that very few E14 members will have such equipment.
    The 1.5us hold over is relatively easy to measure but other types of frequency or phase deviation in the 0.02ppb class are a bit more demanding.
    MK
    It's a massive challege, the specs are impressive.
    Just speculating, maybe there are some ways a theoretical review/RoadTest could be done "on the cheap" (cheap being a relative term!) but still achieving an examination of short-term stability (jitter/phase noise) and longer-term stability (both with and in the absence of GPS disciplining)., and still with useful results.
    For short term stability, the cheapest way I can think of would be to:
    (1) obtain an ultra-low-phase-noise 10 MHz clock source; Microchip have taken the Vectron product line, and theirs were quite cutting-edge. There's OX-2040-BEE-2085-10M0000000 which is just over £1k, but MOQ from Mouser is 3.
    (2) Build (1) into a reference clock source for a spectrum analyzer (your FPC1500 would work for this)
    (3) Build a relatively sharp 10 MHz crystal filter. This would probably be a couple of weeks exercise, would also need a whole load of crystals so you could bin them. This would require a basic VNA (e.g. FPC1500 or even NanoVNA; in fact NanoVNA might be a better choice for this since there's two ports). I've never built a crystal filter, but have matched a filter, and there's lots of online information regarding such filter construction since IF filters are a popular thing!
    (4) Time to add the IQCM-200! Use (3) to provide a notch for it, and feed that into the spectrum analyzer, which is being supplied with the reference from (2).
    (5) Take a noise measurement away from 10 MHz (e.g. 10 kHz offset) and then some manipulation (primarily adding the filter attenuation value to it) will get the phase noise value.
    For longer-term stability, one of the possible tests could be:
    (1) Use two IQCM-200, one with GPS loss, and measure phase difference during 24 hours (e.g. with TinyPFA, see below). This is just a relative measurement, but still useful. Also, it would be good to see what is going on from the data stream that the IQCM-200 apparently outputs.
    The tinyPFA is free firmware (not open source, unfortunately) that can be installed into a NanoVNA-H4 and used standalone or with TimeLab software, which can provide ADEV charts.
    All the above would still cost a few $k but better than several $10k! : ) But would easily consume a lot of time and effort.
    shabaz over 1 year ago in reply to shabaz
    I might add a bunch of 10 MHz xtals to my next Farnell order, just to see what's feasible, since I've always wanted to try building a crystal filter. It could be a handy general-purpose project for checking phase noise of any 10 MHz source (although it still needs a lower-phase-noise reference).
