I am an industrious DIYer with not much experience in this area looking for help figuring out how to
a) find the right relay and
b) hook it up properly (i.e. where is it connected in the system).
I have a solar PV system that charges a 12v deep cycle battery to run one small 35w (220v) pump.
The pump is plugged in to an inverter, of course.
I need a relay to turn off the pump when the voltage in the battery dips below 11.5v (give or take) and turn back on at 12v.
There is an alarm in the inverter that also kicks on when power to it is low.
THanks for your help !
