Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Blog Line filter – The last barrier in the switch mode power supply
  • Author Author: sleuz
  • Date Created: 29 Oct 2013 9:45 AM Date Created
  • Views 547 views
  • switch_mode_power_supply
  • line_filter
  • appnote
  • application_note
sleuz
sleuz
29 Oct 2013
Switch mode power supplies result in conducted interference because they generate radio interference voltage on the mains side. This can interfere with other equipment supplied with mains power. Line filters help to suppress the generated radio interference voltage. These can easily be designed from passive components such as current-compensated line chokes and X / Y capacitors. This article concerns the design of a single-phase line filter.
Summary
In conclusion, a line filter for switch mode power supplies without a common mode choke is not sufficient. Individual capacitors are not sufficient to completely suppress the interference emission. Additional longitudinal coils before the line filter help if further suppression of the differential mode interference is required. Using a line filter, all interference levels are below the permissible limit value and the switch mode power supply can pass an EMC test.
Get the whole article
  • Line Filter - The last barrier in the switch mode power supply
or download it as pdf
  • Line filter – The last barrier in the switch mode power supply (PDF, 613KB)
Visit Würth Elektronik here on element14 for more
