Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Forum 100BASE-T1 PoDL Coupled inductor
Join Würth Elektronik to participate - click to join for free!
  • Replies 13 replies
  • Subscribers 75 subscribers
  • Views 4418 views
  • inductor
  • wurth_elektronik
Taip
Taip over 3 years ago
I am seeking advices for the values/part numbers for the DMI for filtering the power lines for the 100BASE-T1 PoDL with capacitive coupling in an engineering environment.  I am using a pair of the Microchip Eval boards https://www.microchip.com/en-us/development-tool/EV02N47A and add the filter and DMI suggested by TI's app note https://www.ti.com/lit/pdf/tiduet1 . The paper calls out the Wurth's cross-polarity coupled inductor 7448991068 (6.8uH) and 330nH inductors.
When I inserted the contraption the Link got lost. I traced back and the DMI is the part that killed the link. Researching on different paper, I think the value of 6.8uH for the DMI is too low, but I am not sure what is the right value to go with. I only need about 500mA at 12V to be transfered over the T1 line.
Thanks in advance for your help!
  • nwieland
    nwieland over 3 years ago +2
    Hi Taip , we made serveral tests and simulation regarding 100Base-T with PoDL. To fulfill the limits of the 802.3bw (mode conversion & return loss) we recommend this frontend setup as below. But we…
  • Taip
    Taip over 3 years ago in reply to nwieland
    Nicola,
    Thank you very much, I will get the parts ordered. I used the exact large parts called out from the reference design, but did not have good results.
    I also will try out the transformer option. I am waiting for parts to arrive.
    Tai
  • Taip
    Taip over 2 years ago in reply to Taip
    Nicola,
    Thank you very much for your help, I am able to power my remote device over 100BASE-T1 PoDL now.
    Tai
  • nwieland
    nwieland over 2 years ago in reply to Taip
    Hi Taip,
    great to hear that it worked out. If you have more questions we are happy to support you or anyone else.
    Best regards,
    Nicola
