Würth Elektronik
  • Würth Elektronik
Würth Elektronik
Documents SMD Common Mode Line Filter - WE-SCC
  • Author Author: sleuz
  • Date Created: 17 Sep 2012 11:04 AM Date Created
  • Last Updated Last Updated: 28 Oct 2013 9:47 AM
  • Views 868 views
WE-SCC SMD Common Mode Line Filterhttp://i.imgur.com/j3A3X.png
http://katalog-live.we-online.de/media/images/eisos/IndSCC_pf2.jpg
CharacteristicsApplications
  • Enormous common mode impedance
  • Small dimensions
  • High current ratings
  • Attenuation of common mode noise
  • Power supplies
  • Data lines
7345
WE Order Code
Coil Ratio
L
(µH)
Z
(Ω)
IR
(mA)
RDC
(Ω)
UT
(V (AC))
UR
(V)
Farnell Order Code
PDF
744281100
2
10
10000
1100
0.12
500
80
18906801890680
PDF
744281101
2
100
50000
350
0.95
500
80
18906811890681
PDF
744281471
2
470
100000
150
4.3
500
80
18906831890683
1260
WE Order Code
Coil Ratio
L
(µH)
Z
(Ω)
IR
(mA)
RDC
(Ω)
UT
(V (AC))
UR
(V)
Farnell Order Code
PDF
744282010
2
1
1600
4750
0.01
500
80
18906841890684
PDF
744282100
2
10
9000
2250
0.05
500
80
18906851890685
PDF
744282101
2
100
40000
900
0.28
500
80
18906861890686
PDF
744282102
2
1000
160000
250
2.8
500
80
18906871890687
1210
WE Order Code
Coil Ratio
L
(µH)
Z
(Ω)
IR
(mA)
RDC
(Ω)
UT
(V (AC))
UR
(V)
Farnell Order Code
PDF
744284100
2
10
10000
2750
0.04
500
80
18906881890688
PDF
744284101
2
100
40000
1000
0.28
500
80
18906891890689
PDF
744284102
2
1000
160000
300
2.5
500
80
18906901890690
-follow us on element14-
  • bluetooth
  • distribution
  • matching
  • suppressor
  • tape
  • tvs
  • current
  • non-isolated
  • usb/firewire
  • hole
  • conductive
  • housing
  • lan-transformer
  • wlan
  • suppression
  • asi
  • diode
  • factor
  • ic/smps
  • chip
  • ethernet
  • choke
  • emi
  • rs232/rs485
  • line
  • cable
  • integrated
  • surge
  • sleeve
  • gaskets
  • flyback
  • ferrites
  • common
  • toroidal
  • voltage
  • transformer
  • non-integrated
  • shielding
  • gps
  • varistors
  • rf
  • correction
  • axial
  • protection
  • supply
  • interfaces
  • cabinet
  • multiline
  • plate
  • differential
  • mode
  • power
  • isolated
  • antenna
  • filter
  • 868
  • inductor
  • esd
  • can
  • ISM
