    • Avnet Boards Community
XP Power
  • XP Power
XP Power
Forum Ask an XPert -- Questions for the Power Supply Experts
Join XP Power to participate - click to join for free!
  • Replies 38 replies
  • Subscribers 6 subscribers
  • Views 3283 views
  • expert
  • ac_dc
  • power
ksmith
ksmith over 15 years ago
This thread has been closed to new questions.
However, we welcome you to Post Your Question about Embedded in the element14 Community Embedded group. You'll find many fellow members and experts who have just the answer you're looking to find!
Thank You, Your Friends at element14 Community
Kent Smith
Applicaitons Engineer
XP Power
    Kent,
    I want to power a 0.5 ohm heater wire to a constant 40 Watts to use on the end of a hand held probe as a Hotwire Ignition test. Can this be done using just a 15 Volt, 15 amp power supply with a 1ohm series resistor? Just set the PS to 14.5 volts and I have a 40 Watt heater. Am I  missing something?
    Thanks!
    Mike
    I am looking for transistor for switching relay 3.3V. I used BC847 but it is not suitable.
    In switched state is voltage C-E about 1 Volt.
    I am looking for switching transistor with low C-E voltage. Please advise.
    Best regards
    Fero
    Given 1000 CPM reader,2 microseconds average instructions is needed and 1000 LPM is given. How long will it take to print a page?
    Добрый день! Можно-ли в сварочном инверторе поменять SKW20N60SKW20N60HS(их нет в каталоге Farnell) на SKW20N60SKW20N60. Если нельзя, тогда подскажите пожалуйста аналог. Заранее благодарен.
  • RWM
    RWM over 13 years ago in reply to Former Member
    SKW20N60SKW20N60HS это "high speed" SKW20N60SKW20N60 для частот выше 30 кГц. Я думаю можно поменять на
    FAIRCHILD SEMICONDUCTOR - HGTG12N60A4DHGTG12N60A4D
    Former Member over 13 years ago in reply to RWM
    По описаниям подходят (я только начинаю разбираться в даташитах т.е. сравнивать наиболее важные показатели IGBT). Жаль только, что сайт не руссифицирован. Приходится пользоваться переводчиком. А в остальном всё хорошо. Спасибо за столь быстрый ответ.
    Buenos días
    Quisiera saber si este producto http://mexico.newark.com/avago-technologies/heds-5500-g06/optical-encoder/dp/54K2759
    es igual o puedo utilizarlo en un CTP (Plate Driver 8) que tiene el siguiente número de serie: HEDS-5500 I12.
    Gracias.
    Hi Kent, I need some help with a heat pump system I'm currently developing, would you be able to help me with a couple of answers? (I see that your expertise is in Power Supply image)
    Former Member over 13 years ago in reply to Former Member
    Добрый день! Сравнивая даташиты этих отоэлектронных приборов, я понял, что буквено-цифровое обозначение после знака # указывает на диаметр вала и Resolution (Cycles/Rev). На этой странице есть ссылка на хороший даташит  http://www.farnell-volga.ru/product.html?p_id=1161195
    Good day! Comparing these datasheets otoelektronnyh devices, I realized that the letter-numeric designation after the # sign indicates the diameter of the shaft and Resolution (Cycles / Rev). This page has a link to a good datasheet. http://www.farnell-volga.ru/product.html?p_id=1161195  Sorry for my English.
    Вот здесь ещё описания  http://catalog.gaw.ru/index.php?page=component_detail&id=2501
