    Members
    • Avnet Boards Community
    • Choose Another Store
Raspberry Pi
Raspberry Pi
Blog Introducing the NEW Raspberry Pi Compute Module
Raspberry Pi requires membership for participation - click to join
Blog Post Actions
  • Subscribe by email
  • Author Author: lbittner
  • Date Created: 7 Apr 2014 11:59 AM Date Created
  • Views 1114 views
  • Comments 25 comments
  • raspberry
  • applications
  • raspberry_pi_compute_module_development_kit
  • industrial
  • pi
  • compute
  • embedded
  • raspberry_pi
  • io_board
  • raspberry-pi
  • development
  • kit
  • design-in
  • module
lbittner
lbittner
7 Apr 2014
Designing in the Future: Raspberry Pi Compute Module Development Kit
Coming Summer 2014!
The new Raspberry Pi Compute Development Kit enables design engineers
to harness the power of the Raspberry Pi for embedded applications.
  • Small and Powerful. SODIMM sized (6.5cm by 3cm) Raspberry Pi board contains the BCM2835 chip with 512MB RAM with an on board 4GB eMMC Flash memory for booting the OS.
  • Flexible and Rapid Prototype Development. A fully functional IO board is part of the development kit which supports an extensive GPIO and multiple connectors to help foster rapid prototype development with access to all of the BCM2835 functionality.
  • Custom Hardware and Software Solutions. Benefit from fully functional Linux server running on your ‘design-in’ hardware solution. This unique combination of services will help define the next generation of the ‘Internet of Things’
Compute Module Development Kit Technical Specifications:
Compute Module:
  • SODIMM sized 6.5cm by 3cm board
  • BCM2835 chip with 512MB RAM
  • On board 4GB eMMC Flash memor
  • 200 pin edge connector
IO board:
  • Multiple GPIO interfaces
  • 1 x micro USB connector type B
  • 1 x USB connector type A
  • 2 x CSI ports for camera boards
  • 2 x DSI ports for display boards
  • Full size HDMI port
Harness the power of the Raspberry Pi for your embedded applications!
Request Consultation...
Complete this form and one of our Design Representatives will call you to discuss your embedded design.
See schematics for:
Compute Module
Io Board
  • raspberrystore
    raspberrystore over 8 years ago in reply to Former Member +2
    Its just who develops an IO-board first, with only ethernet, GPIO (USB?) and power (on the same side). Sadly not me, Id really like to test them!
  • lbittner
    lbittner over 8 years ago in reply to jamodio +1
    Thanks for alerting us, jamodio! The two links will now take you and other members to separate documents.
    Best,
    Lauren
  • Former Member
    Former Member over 8 years ago +1
    Ethernet port?
  • jamodio
    jamodio over 8 years ago
    Also, it seems that both links for the schematics above takes you to the same file, which is the schematics for the Compute module.
    BTW, good first step forward about releasing the schematics in advance.
    -J
    • Up 0 Down
    • Reply
  • jamodio
    -J
    • Up 0 Down
    • Reply
  • lbittner
    Best,
    Lauren
    • Up +1 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
