    Members
    • Avnet Boards Community
    • Choose Another Store
Raspberry Pi
Raspberry Pi
Blog My Very First Ever Python Programme and on a Raspberry Pi
Raspberry Pi requires membership for participation - click to join
Blog Post Actions
  • Subscribe by email
  • Author Author: dubbie
  • Date Created: 14 Mar 2020 1:08 PM Date Created
  • Views 353 views
  • Likes 8 likes
  • Comments 18 comments
  • python;
  • rpi-bc
dubbie
dubbie
14 Mar 2020
I wished to join the Raspberry Pi day activity so I decided that I would combine this with writing my very first own Python programme as well. I recently did an online Python course which had some directed programmes in but I wanted to make up my own unassisted. As I am shortly going out for lunch this had to be very short so I decided on
print("Hello and Happy Pi Day")
Next I needed my Raspberry Pi which is still integrated into my HoloPiBot (HoloPiBot #10 : It Actually Works - It Really Does! ) so I just plugged in cables, keyboards, mouse and eventually power supply  (when I found it!) as I vaguely remembered how to do. Turned it on and amazingly it still all worked. I must have learned something after all. There is a bit of video of this, but the battery on my camera ran out - it doesn't seem to be charging so I might need a new camera - and this is all I captured.
Following this I needed to start Python. I had no idea whether my Pi had Python so I decided to Google it, using my Pi, of course. Seems that it does have Python so I just went to the command line, typed in Python, then the programme above and it worked! If I have time over this weekend I might now try flashing an LED on and off - no promises though.
The Power of computing.
Dubbie
  • airbornesurfer
    airbornesurfer over 2 years ago in reply to dubbie +4
    Sudo ("superuser do") is basically the shorthand for all elevated privileges in Linux. Or, as Randall Munroe so eloquently illustrated:
    beacon_dave over 2 years ago in reply to dubbie +4
    You may find this MagPi beginner's guide on the Python GPIO Zero library of interest:
    https://www.raspberrypi.org/magpi-issues/Essentials_GPIOZero_v1.pdf
    shabaz over 2 years ago in reply to beacon_dave +4
    With newer versions of Python 3, there's another option too - really nice:
    import math
    print(f"Hello and Happy {math.pi} Day")
    The Jive syntax highlighting has not kept up though! : )
  • clem57
    clem57 over 2 years ago
    Not a bad beginning dubbie . For flashing led, you may need sudo.
    Clem
    • Up +3 Down
    • Reply
    dubbie over 2 years ago in reply to clem57
    Clem,
    I was under the impression that you can control Pi I/O directly from Python. Is this not true? Also, what is sudo? I've seen it mentioned before and I've probably typed it in but I do not know/understand what it does.
    Dubbie
    • Up +1 Down
    • Reply
  • clem57
    clem57 over 2 years ago in reply to dubbie
    This gives administrator permission usually root. Unless your I'd is added to a special group, you need this to work on the hardware level.
    • Up +2 Down
    • Reply
    • Up +4 Down
    • Reply
    dubbie over 2 years ago in reply to airbornesurfer
    Matthew,
    That's make sense.
    Dubbie
    • Up +2 Down
    • Reply
    Clem,
    This also makes sense. However, if I can give myself permission to use the hardware level, it doesn't seem to confer much protection. Is it like being Administrator in Windows?
    Dubbie
    • Up +1 Down
    • Reply
    dubbie over 2 years ago in reply to beacon_dave
    Dave,
    Thanks for this. I have downloaded this eBook and will review it later. Will these commands also work with an ordinary Pi?
    Dubbie
    • Up +1 Down
    • Reply
    Dave,
    Dubbie
    • Up +1 Down
    • Reply
Element14
An Avnet Company © 2022 Premier Farnell Limited. All Rights Reserved.
  • Twitter
