I work in a hardware startup "Modulowo" and I would like to propose a new, universal connector for development kits - Modulowo duoNECT
. The connector provides the basic interfaces like UART, I2C, SPI, 1-Wire, a few I/O pins and ID (Identification) pin. The advantage of our connectors is possible to mount by traditional pin 2.54 mm or directly on the base plate thanks to castellated holes. Our solution is not only duoNECT
connector, but also add-on modules - Explore
boards - and adapter for Raspberry Pi 2 or B +. The adapter has three duoNECT
connectors, but it will be six modules can be connected. In addition, EEPROM memory and 12-bit Analog-to-Digital Converter (16-bit optional). A little more detail: http://blog.modulowo.com/en/modulowo-duonect-czyli-uniwersalne-zlacze-dla-modulow-elektronicznych/
Are our solution can be an interesting proposition? A few photos below:
Robert Peter Oakes
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
Comment-
Robert Peter Oakes
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
