Raspberry Pi
Raspberry Pi
Blog Raspberry PI 2 and a 30 min guide to installing the new Prod version of Windows 10 IoT
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: Robert Peter Oakes
  • Date Created: 30 Jul 2015 8:05 AM Date Created
  • Views 1775 views
  • Comments 5 comments
  • pi2_launchart
  • raspberry-pi
  • raspberry_pi_2
  • raspberrypi
  • tutorials
  • rpi_2
  • windows_iot
  • visual_studio
  • windows_10
Robert Peter Oakes
Robert Peter Oakes
30 Jul 2015
I will be adding a load of details tomorow for this but for now i wanted to share the install vid of the latest windows IoT for the PI2.
So it was finally released today 29th July 2015 I thought I would give it an immediate install and share with you all. So in this the first video featuring the Production version of Windows 10 for IOT and Visual Studio 2015 Community on Windows 10 we will go through the new way to prep the SD card, get the primary screen up and running and have a quick look at what may be new
In follow up videos I will look at migrating the RC version of a Visual Studio project as there not compatible and I will use my DAC8734 project for that purpose
MS has all the files for download, here are a few links to get you started, I will be following up with a detailed Post
Visual Studio 2015 Community Download: https://www.visualstudio.com/downloads/download-visual-studio-vs
IoT Core Templates for Visual Studio: https://visualstudiogallery.msdn.microsoft.com/06507e74-41cf-47b2-b7fe-8a2624202d36
IoT Core for the Raspberry PI http://ms-iot.github.io/content/en-US/win10/SetupRPI.htm This link also has additional instructions, I will be providing my take on the install when I make my Post but here is the original and what I followed to start with
I am not sure how many of the MS Sample projects have been updated for the production Visual Studio but they can be found here https://dev.windows.com/en-us/iot
If you have just installed windows 10 on your PC, you may have to enable "Developer Mode", instructions can be found here https://msdn.microsoft.com/library/windows/apps/xaml/dn706236.aspx
And more dev kits and samples can be found here too https://msdn.microsoft.com/en-US/windows/hardware/dn913721(v=vs.8.5).aspx
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to Robert Peter Oakes +1
    No elderly persons where harmed or tested in proving this theory / issue
  • clem57
    clem57 over 10 years ago
    Can you hi light only the changes?
    Thanks,
    C
  • cstanton
    cstanton over 10 years ago in reply to clem57
    From what I've read the changes are mainly that it supports bluetooth and wifi now, though I haven't seen details of what exactly. VideoCore and PiCam support are still in development.
  • cstanton
    Robert Peter Oakes over 10 years ago in reply to cstanton
    From what I am seeing right now that would be correct, except they still have not posted a hardware list I have found and the standard WIFI and Bluetooth I have that work on Raspbian out of the box and from E14 dont work image
    Bug Fixes... SPI it still an elderly frail person with a zimmer frame that cant climb stairs without resting after every step. you will eventually get there and each step is at full speed but it still takes forever to get to the next landing (create a waveform as an example)
