Raspberry Pi
Raspberry Pi
Blog Raspberry Pi Sense Hat - Enabling The Joystick
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: Former Member
  • Date Created: 23 Jan 2017 5:00 PM Date Created
  • Views 3373 views
  • Likes 9 likes
  • Comments 8 comments
  • sense hat
  • sense_hat
  • raspberry_pi sense_hat
  • raspberry_pi
  • raspberry pi sense hat
Former Member
Former Member
23 Jan 2017
Having had some fun playing with the display on the Sense Hat I moved on to trying to utilise the Joystick. However copying the examples set out in the Sense Hat API results in the following error
AttributeError: 'SenseHat' object has no attribute 'stick'
Upon further investigation it turns out that the sense_hat.py library doesn't include any functionality for the joystick, trying to run sudo apt remove --purge sense-hat then sudo apt-get update and sudo apt-get install sense-hat only installs the same version without the joystick functions.
Navigating to the github repositories shows that there is an updated version that does include the joystick functions, to get the updates were going to have to manually install them.
Time to implement the update!!
Step 1.
Open up a terminal on the Raspberry Pi (or if your going over ssh just use the terminal your already in).
Navigate to the sense_hat python directory
cd /usr/lib/python2.7/dist-packages/sense_hat
delete the existing files
sudo rm __init__.py sense_hat.py __init__.pyc sense_hat.pyc
Step 2.
Download the new files straight from github
sudo wget https://raw.githubusercontent.com/RPi-Distro/python-sense-hat/master/sense_hat/__init__.py
sudo wget https://raw.githubusercontent.com/RPi-Distro/python-sense-hat/master/sense_hat/sense_hat.py
sudo wget https://raw.githubusercontent.com/RPi-Distro/python-sense-hat/master/sense_hat/stick.py
Step 3.
We just need to make a slight alteration to the sense_hat.py file that was downloaded, open the file using nano:
sudo nano sense_hat.py
Line 17 (highlighted in the picture below) reads
from .stick import SenseStick
the .  needs deleting from in front of the work stick so it reads:
from stick import SenseStick
Press ctrl+o then enter to save changes and ctrl+x to exit nano.
Thats it! happy playing!!
Here's an example code and video showing how to move a pixel around using the joystick:
from sense_hat import SenseHat
sense = SenseHat()
x = 3
y = 3
def draw_dot():
 sense.clear()
 sense.set_pixel(x,y,255,90,90)
def pushed_up():
 global y
 y = y - 1
 if y < 0:
  y = 0
 draw_dot()
def pushed_down():
 global y
 y = y + 1
 if y > 7:
  y = 7
 draw_dot()
def pushed_left():
 global x
 x = x - 1
 if x < 0:
  x = 0
 draw_dot()
def pushed_right():
 global x
 x = x + 1
 if x > 7:
  x = 7
 draw_dot()
sense.stick.direction_up = pushed_up
sense.stick.direction_down = pushed_down
sense.stick.direction_left = pushed_left
sense.stick.direction_right = pushed_right
draw_dot()
This video is unavailable.
  • Former Member
    Former Member over 9 years ago in reply to Jan Cumps +3
    Music
  • Former Member
    Former Member over 9 years ago in reply to spannerspencer +2
    When I found that wall paper I immediately went looking for emulator roms, by far the best is the arcade version all round. The early computers couldn't compete with the graphics, rich sound and responsiveness…
  • spannerspencer
    spannerspencer over 9 years ago +1
    Excellent work Lucie -- really useful. Thanks for this! And check out that Metro Cross wallpaper!! I LOVE that game -- not played it in soooo long Had it on the Speccy and Amiga!
  • tonygo
    tonygo over 9 years ago
    Very useful blog - thanks.
    How do you make it work in Python 3?
    Why has the update not been included in the official update list?
    I used pygame to get it to work
    # Modified from Astro Pi Guide for Teachers
    #      raspberrypi.org/resources
    # Tony Goodhew 26 Sept 2015
    import pygame
    from pygame.locals import *
    pygame.init()
    pygame.display.set_mode((90,5))#Big enough
    sense = SenseHat()
    sense.clear()
    print("Steer the BLOB with the joystick")
    print("  * Up, Down, Left or Right *\n")
    print("Quit with Joystick Centre Button, RETURN or ESC\n")
    running = True
    x = 0
    y = 0
    sense.set_pixel(x, y, 255, 255, 255)
    while running:
        for event in pygame.event.get():
            if event.type == KEYDOWN:
                sense.set_pixel(x, y, 0, 0, 0)  # Black 0,0,0 means OFF
                if event.key == pygame.K_DOWN and y < 7:
                    y = y + 1
                elif event.key == pygame.K_UP and y > 0:
                    y = y - 1
                elif event.key == pygame.K_RIGHT and x < 7:
                    x = x + 1
                elif event.key == pygame.K_LEFT and x > 0:
                    x = x - 1
                elif event.key == pygame.K_RETURN:
                    running = False
                    sense.clear()
                    print("** BYE from Joystick **")
                if running: sense.set_pixel(x, y, 255, 255, 255)
            if event.type == QUIT:
                running = False
                sense.clear()
                print(" ++ BYE from mouse QUIT ++")
  • owenevans00
    owenevans00 over 7 years ago in reply to tonygo
    It's a bit late for this thread but I can confirm that the same issue exists in 2018, and the same fix works identically for python 3
  • owenevans00
