Just got my new RaspberryPi 4. I’d read about the CPU running hotter than previous models, so I decided to have a look for myself.
https://www.elinix.org/RPI_vcgencmd_usage gave details of how to do this.
I decided to wrap this up in a PyQt5 application so that I could monitor the temperature more easily.
So if anyone wants a copy here it is (to cut and paste) or download from:
http://www.concept-computing.co.uk
Login as Guest
Screenshot:
Code:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# cpu_temp.py
# Copyright 2019 alan.warden1@gmail.com
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
# MA 02110-1301, USA.
# see https://www.elinix.org/RPI_vcgencmd_usage
# for more info
import sys
import os
from PyQt5.QtWidgets import (QApplication, QDialog, QGridLayout,QLabel,
QLineEdit, QPushButton, QStatusBar, QMainWindow, QDesktopWidget)
from PyQt5.QtGui import (QGuiApplication, QIcon, QFont, QFontMetrics)
from PyQt5.QtCore import (Qt, QTimer)
class stats_dialog (QDialog):
def __init__(self):
super(stats_dialog, self).__init__()
# pastel yellow for the dialogue
self.setStyleSheet("background-color: rgb(250, 250, 210);")
self.grid = QGridLayout ()
self.cpu_temp_lbl = QLabel ('CPU Temperature:')
self.cpu_temp_value = QLineEdit ('CPU')
self.cpu_temp_value.setReadOnly (True)
self.quit_btn = QPushButton ('&Quit')
self.shutdown_btn = QPushButton ('&Shutdown')
self.tim = QTimer (self)
self.tim.setInterval (5000)
self.tim.start()
# build the screen
self.grid.addWidget (self.cpu_temp_lbl,0,0)
self.grid.addWidget (self.cpu_temp_value,0,1)
self.grid.addWidget (self.quit_btn,1,0)
self.grid.addWidget (self.shutdown_btn,1,1)
self.setLayout (self.grid)
# signals
self.tim.timeout.connect (self.tim_update)
self.quit_btn.clicked.connect (self.quit_prog)
self.shutdown_btn.clicked.connect (self.kill_computer)
def tim_update (self):
os.system('vcgencmd measure_temp > cpu.txt')
file_in = open ('cpu.txt')
line = file_in.read ()
file_in.close ()
line2 = line.split ('=')
self.cpu_temp_value.setText (line2[1])
def quit_prog (self):
QGuiApplication.instance().quit()
def kill_computer (self):
os.system ('sudo shutdown -h now')
class main_win (QMainWindow):
def __init__(self):
super(main_win, self).__init__()
self.setWindowTitle('System Stats')
self.sb = QStatusBar ()
self.tim.setInterval (60000) # 1 minute
self.tim.start ()
self.setStatusBar (self.sb)
self.dlg = stats_dialog ()
self.setCentralWidget (self.dlg)
# signals
self.tim.timeout.connect(self.tim_update)
os.system('uptime > uptim.txt')
file_in = open('uptim.txt')
file_in.close ()
line2 = line.split (',')
msg = line2[0]
if 'min' not in msg:
msg = msg + ' hrs'
self.sb.showMessage ('Time: ' + msg)
def main(args):
app = QApplication(sys.argv)
scr = main_win()
scr.setWindowFlag (Qt.WindowStaysOnTopHint)
scr_size = scr.geometry()
screen = QDesktopWidget().screenGeometry()
h_pos = (screen.width() - scr_size.width() ) / 2
v_pos = (screen.height() - scr_size.height() ) / 2
# Start roughly in the middle. Then move it to suit
scr.move(h_pos-h_pos/3, v_pos)
scr.show ()
sys.exit(app.exec_())
if __name__ == '__main__':
sys.exit(main(sys.argv))
Notes:
This was written in Geany, you’ll need to set the build commands from python to python3 i.e
Notes:
Notes:
Also set the Tab Type to Spaces
Regards
Alan
dougw
Cancel
Vote Up
+4
Vote Down
Sign in to reply
More
Cancel
Comment-
dougw
Cancel
Vote Up
+4
Vote Down
Sign in to reply
More
Cancel
