    • Avnet Boards Community
Raspberry Pi
Raspberry Pi
Blog Watchdog Timer for the Raspberry Pi
Raspberry Pi requires membership for participation - click to join
Featured Articles
Announcing Pi
Technical Specifications
Raspberry Pi FAQs
Win a Pi
GPIO Pinout
Raspberry Pi Wishlist
Comparison Chart
Quiz
  • Author Author: mistertee
  • Date Created: 19 Jul 2016 10:15 AM Date Created
  • Views 5857 views
  • Comments 19 comments
  • autostart
  • watchdog timer
mistertee
mistertee
19 Jul 2016
Like all PCs the Raspberry Pi is likley to hang up during operation due to unexpected events not being catered for in the code. In an unattended application where the program automatically starts this can be a problem as there is no one around to restart the RPi. If there is no keyboard or HDMI monitor this is by power cycling. The Raspberry Pis internal watchdog timer has a poor reputaion - there are many comments about it being unreliable. This post presents a simple external watchdog timer.
Although there are dedicated power supply monitoring chips this solution uses components that are likley to be in most electronic hobbyists kit - based around the popular 555 timer.
The programme has to supply a Hi going pulse every few seconds. If there is no pulse for more than about 60 seconds the 555 output on Pin 3 will go low. This is coupled through to the on-board reset pin of the Raspberry Pi through a capacitor to issue a low going pulse which resets the Pi.
A capcitor is used here so that only a pulse going from Hi to Low will reset the raspberry Pi. A constant Lo voltage which is present while the raspberry Pi is starting up will have no effect.
If a shorter time is required then either reduce the value of R1 (1Mohm) or reduce the value of C1 (100 uF).
The LED pulses every time a Hi Pulse is issued to provide a visual indication to the user that everything is fine. The 555 timer does not easily provide a retriggerable monostable function that is required for a watchdog timer. Diode D1 is used to discharge the capacitor every time a pulse is received.
The reason the delay before a reset is set at more than 60 seconds is that the Raspberry Pi takes more than 30 seconds to start up.
Click here for a guide to setting the Raspberry Pi to autostart.
The image above shows the connection to the Reset pin of the Raspberry Pi.
Summary
Althogh the Raspberry Pi has an in-built watchdog timer, this has a poor reputaion. This watchdog timer is a reliable way of resetting the Raspberry Pi in remote applications where there is a risk of it hanging up due to the code not handling unexpected events correctly.
  • mistertee
    mistertee over 8 years ago in reply to mcb1 +1
    True - I am sure there is a much better chip out there. 555 timers are like Marmite - you either love it or hate it. I had some in stock (doesn't one always) and couldnt be bothered to order a new IC and…
  • roetske
    roetske over 8 years ago
    Hello found your hardware schematic watchdog was looking for this for extra protection io control.
    When you control eg heater with relay trough raspberry control. Extra safety  is never bad. I like your control with pulse. However reading other comments , instead of resetting pi.
    Catch via input in rasp (output from your timer) running in separate program fault from to restart processes or reboot .
    for io control Why not cutoff output or supply to output using your schematic?
    If your rasp is still frozen at least your outputs are disabled.
    If you use different powersupply for io your setup with 555 timer is excellent to cutoff power to all active outputs. eg heater control rasp freezes  outputs stay high. Not a situation that we want.
  • roetske
