Raspberry Pi Forum Data recorder
  • Replies 16 replies
  • Subscribers 691 subscribers
  • Views 3347 views
Data recorder
o.thornwall
o.thornwall over 5 years ago
I'm in need of coming up with a device that will record actions of another device, that can also give the exact date and time of that action
It will run on Battery power.
what is the minimum idea I may wish to have ?
Any idea are welcome.
Thank you, OT
  • o.thornwall
    o.thornwall over 5 years ago in reply to fmilburn
    So the "Shield" is a part that goes on top of an Arduino, and I have to put it has to be put together ?
    michaelkellett over 5 years ago in reply to o.thornwall
    If you don't want to build anything take a look at these.
    https://www.lascarelectronics.com/data-loggers/voltage-current
    They do them for temperature as well.
    If you motion light is a traditional tungsten bulb you could get non contact measurement from the temperature rise.
    If it's LED based you will need to measure current or voltage and to hack into it.
  • fmilburn
    fmilburn over 5 years ago in reply to o.thornwall
    The shield is already assembled and requires only to be placed onto the Arduino. The Arduino is then programmed.  There are full instructions in the learn section link on Adafruit.
  • kmikemoo
    kmikemoo over 5 years ago
    Huge kudos to the E14 Community for showing their professionalism and grace.  shabaz, genebren, fmilburn and michaelkellett, GREAT JOB!
    I opted to delete my recommended solution post and move on.  You all chose the higher road.  That's why you're the best.
    • Vote Up +5 Vote Down
  • phoenixcomm
    phoenixcomm over 5 years ago
    o.thornwall  gee that's really sparse, and it is a big universe.  first, you need to know a few things:
    • what type of data stream is it? monolithic or disperse??
    • how long to you want to record for time and size
    In my flight simulator, I have a data recorder but it's all timecoded I record the following things
    • Navbus Messages ~100pfs
    • CANaerospace Messages
    • Radio frequencies
    • pilot control inputs.
    • and on and on.
    ~~Cris
    BTW for time, you can use an NTP server from the Internet providing your thing has ethernet connectivity.
  • o.thornwall
    o.thornwall over 5 years ago in reply to michaelkellett
    I have no problem with building the shield if necessary. I just wanted to confirm if it was or was not. The article I was looking at was not real clear.
