    Members
    • Avnet Boards Community
    • Choose Another Store
Forum Small monitor options for R-Pi
Raspberry Pi requires membership for participation - click to join
  • Replies 38 replies
  • Subscribers 281 subscribers
  • Views 2510 views
So, I know many people will want to hook the R-Pi up to a 50-inch HDTV, but some of us will want to keep it small (such as for a CarPC). I am not thinking about touchscreen capability, simply small LCD displays. So, there are $1000 5" to 8" LCDs meant for digital photography, but that is nuts. So, I found that small portable LCD TVs should be the way to go. The cheap Coby and Axion 7" LCD TVs have RCA/composite video input jack, and luckily the R-Pi also has an RCA/composite video output jack!  They are about $50 to $60.
Coby
http://www.bing.com/shopping/coby-tf-tv791-7-lcd-tv/specs
Axion
http://www.bing.com/shopping/axion-axn-8701-7-lcd-tv/specs
    Former Member over 11 years ago in reply to Former Member +1
    I was thinking of going battery powered, with one of these: http://www.lilliputuk.com/monitors/hdmi/668gl/
  • jamodio
    jamodio over 10 years ago +1
    If you want to go smaller than that AdaFruit has some options: http://www.adafruit.com/products/913 http://www.adafruit.com/products/912 http://www.adafruit.com/products/911 I tested the Rpi with a 7"…
    Former Member over 10 years ago +1
    Although I haven't yet received my RPi (it's supposed to arrive this week), I already bought a 7" lcd monitor on ebay that comes with hdmi and support of HD resolutions (native resolution is 840x480 I…
    Found another...
    Audiovox
    http://www.bing.com/shopping/audiovox-fpe709-7-lcd-tv/specs
    I was thinking along the lines of either a back up camera screen (they actually have decent resolution if you buy the right one) or one of those screens that clips on to a video game console for car trips and stuff.
    Dont let the $20 pricetag fool you, shipping to my zip code was almost another $20.
    http://www.ebay.com/itm/Zenith-Flat-Panel-LCD-Display-Game-Screen-for-Xbox-PS2-Brand-New-Sealed-/190644769348?pt=Video_Games_Accessories&hash=item2c63505244#ht_500wt_1156
    That would take a little modification but should be easy enough to hook up to the Rpi. But this one is much easier
    http://www.ebay.com/itm/7-Color-TFT-LCD-Car-Rearview-DVD-VCR-Backup-Camera-Display-Monitor-w-IR-Remote-/300657147646?pt=LH_DefaultDomain_0&hash=item46008ffefe#ht_3476wt_1265
    I'm not sure exactly what functions your CarPC will support- how much resolution do you need?  If you need to read a lot of text, that's different from just video, audio playlists or a few icons and readouts.
  • notdodgy
    notdodgy over 11 years ago
    A cheaper option may be a portable DVD player - I think some of these come with an AV input.
    Former Member over 11 years ago in reply to notdodgy
    That was my first idea, and you could gut the dvd player part to put the raspberry pi in there as well. But the one I have does not have av in. I am still thinking about buying one that does. It would be pretty cool  form factor wise. But I can not find a good deal on one that I know had av inputs.
  • mahjongg
    mahjongg over 11 years ago
    Be aware that the monitor must have either HDMI, or composite video input (Yellow RCA input, directly or through a SCART adapter).
    So no "RGB", "component video" or S-Video (mini DIN-4). These are all unsupported, as is VGA.
    Interestingly the RasPI does support raw LCD panels, through its 15-pins MIPI Display Serial Interface (DSI) connector, although at the moment there doesn't seem to be any software support for it, and the pinning of the 15-pins connector is also unknown.
    The RasPI supports a range of digital low resolution settings such as 640x350 (EGA); 640x480 (VGA) and 800x600 (SVGA)
    on its composite output it can handle both PAL 576i interlaced 720x576 50 Hz as NTSC 480i interlaced 720x480 60Hz, as well as some variations on PAL and NTSC, for example Japanese NTSC. Other low resolutions seem to be possible with some "tweaking", currently the tweaking to get composite video resolutions has not seem to be finished yet, but the hardware can do at least the above.
  • fustini
    fustini over 10 years ago
    I've been interested too in finding a small, portable & inexpensive display for the Pi.  I finally ordered a composite LCD from Amazon: http://www.element14.com/community/groups/raspberry-pi/blog/2012/07/04/cheap-portable-lcd-for-raspberry-pi.  The resolution is too low for normal use but I think it will be helpful as a screen embedded in a project to display larger text and graphics.
  • jamodio
    I tested the Rpi with a 7" TFT LCD TV/Monitor, I didn't find the way to tweak the NTSC signal, I'd agree that the TV/Monitor is not a great thing, but the text from the Rpi is practically unreadable.
    A Picture is worth a thousand words ...
    Is two, two thousand ? Next picture is from a 21" HD Monitor via the composite video input
    I've to admit that I'm not using a high quality video cable, and there is some noise on the signal, there is flickering on the colors and text looks like if the pixel clock had a lot of jitter.
    OK, lets make it three thousand then ... after startx
    Not bad, but with the noise moving the pixels and flickering on the colors, you may be able to survive in text mode but for graphic mode I think the best way is to go with the HDMI interface.
    Signal quality will probably be better with a better cable (I'm using a standard 3xRCA AV cable).
    -J
    Although I haven't yet received my RPi (it's supposed to arrive this week), I already bought a 7" lcd monitor on ebay that comes with hdmi and support of HD resolutions (native resolution is 840x480 I think). I think the direct signal from HDMI to a screen is much more preferred over a simple analog SD signal like the one you get from the RCA on the Pi.
    Here's how it looks from a regular boot screen, it has very decent contrast:
    https://lh3.googleusercontent.com/-NnqGq9nHdYQ/T6mBdTUQUmI/AAAAAAAADCE/6wxoL8LEfRg/s640/IMG_6099.JPG
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
  • Twitter
