Raspberry Pi Forum New Pi 2's won't boot from microSD card?
  • Subscribers 706 subscribers
  • Views 894 views
  • raspberry_pi_space
starksm64
starksm64 over 11 years ago
I took a a Pidora image that I have running on a Raspberry Pi B and put it onto an 8Gb microSD card from Kingston. I checked the image by booting up the Pi B from it in an adapter card. I have two Pi 2's, and when I try to boot them up, I see the red and green light flash on for a bit, then the green light goes out, while the read led stays on. There is no HDMI output during the initial flash of the green light. I have tried a couple different power supplies, the largest one providing 5V and 1A.
I'm not sure what else to try at this point other than trying another boot image once I get another microSD card.
Any suggestions?
  • starksm64
    I found a 5V 2A power supply and tried that with the same result, so it does not seem to be a power supply issue.
  • gadget.iom
    gadget.iom over 11 years ago
    I would suggest getting one of the latest images and putting that onto an SD card. Raspbian seems to be updated more frequently than Pidora. If you can get it to boot then you can be fairly confident that your hardware is ok.
  • michaelwylie
    michaelwylie over 11 years ago
    Not all SD cards are created equal. I would try a different card.
  • starksm64
    starksm64 over 11 years ago in reply to gadget.iom
    Thanks, I reformatted the card and installed the NOOBS netboot and that is at least booting to the install screen, although there is a problem resizing the partition, but at least I know the board is fine. At least I have something to work with now.
  • gadget.iom
    gadget.iom over 11 years ago in reply to starksm64
    Great. Get back to us if you have any issues.
    mcb1 over 11 years ago in reply to starksm64
    NOOBs automaticaly resizes it to the maximum.
