Raspberry Pi Forum i  can't seem to get my mini wi-fi usb to work 802.11n..
  • Subscribers 677 subscribers
  • Views 392 views
i had ordered the mini wi-fi usb,, 802.11n   but cannot get it to work,  I have never setup a wi-fi before,  It came with a small CD with a few OSs on it,,, I plugged the wi-fi into my laptop usb and used the setup.exe in the windows folder on the small CD.  everything seemed to load.  i put the wi-fi into my R-pi usb and tried to access the internet and got Hostname error.   I  seen that the small CD had a Linux folder but did not know how to load it onto the wi-fi.   Please help.  it must be simple, but i have never done it before.   Is there s setting on the R-pi that I have to set or something ?  Chuck
    need more details. what kind of wic did u get? a lot of them are lemons on the RPI, you need a low power NON NETGEAR model. I suppose you could get a netgear to work, but since your asking, probably not. My quick answer is go to K-mart and get that cheapo "ON-Networks" wic. it works like a champ and was plug n play and costs 14 bucks. the more sophisticated ones are problematic.
  • fvan
    0 fvan over 11 years ago
    Which wifi adapter do you have ?
    You can find a list of adapters know to work here: RPi USB Wi-Fi Adapters - eLinux.org
    Also, if your usb wifi adapter requires more power than the pi can provide on usb, you might want to try a powered usb hub to connect the adapter to.
    Frederick
  • fvan
    You also need to configure the pi to connect to the correct network:
    • via command line: Setting up Wifi with the Command Line | Adafruit's Raspberry Pi Lesson 3. Network Setup | Adafruit Learning System
    • or via gui: Video 3: Getting your Pi Online
    Well worth purchasing the Raspberry Pi User Guide by Eben Upton - the founder of Raspberry Pi.  Chapter 4 has a detailed description of how to set up a wireless adapter.  I got lucky with the D-Link 131 -  it picked it up automatically and configured network - of course you have to be connected to your router via Ethernet while doing this - again assuming you have the model B.  The model A does not have an Ethernet port and you would have to use a USB to Ethernet converter.
