    • Avnet Boards Community
Raspberry Pi Projects
Blog Happy Holidays with the Drinkmotizer 2
  • Date Created: 3 May 2014 3:24 AM Date Created
  • Views 1437 views
  • robotics
  • control
  • robot
  • raspberry_pi
  • stepper
  • rpi
  • raspberry_pi_projects
  • motor
  • drinkmotizer
3 May 2014
See the original Drinkmotizer video - and how it was built! (follow this link)
Celebrate the winter holidays with your own drink mixing robot. Drinkmo never lets you down!
The Drinkmotizer interface.
But, Drinkmo is different too. I made a few changes to its operation. First, I changed out the sub 100oz/in stepper motor for a 280 oz/in alternative. I did this so that the drink platforms could blast through any obstacle. Whether it be debris, dry triple sec, or someone’s finger… right through!
Second, I swapped out the stepper driver for a Gecko G210X, single stepping motor. I was originally doing 1/10th micro-stepper, and hand a maximum speed. Now, I am able to step up the speed, so to speak. I set it to be a little faster. Future modifications will make it move nightmarishly fast, you have my word on that.
Third, the onboard air regulator was originally taking 800 psi air from a paintball gun tank to operate the chaser module. The problem here was frequent air line bursts. So, I made an adapter to go from a portable air compressor to the Drinkmo regulator system. With a maximum of 100 psi from the air compressor,  air line compromises were over. I also upped the chaser bottle pressure from 5 psi to 15 psi to force the chaser out faster.
I have big plans from Drinkmo in the coming months. Almost a complete overhaul. Cheaper kits to follow too!
C
See more news at:
  • tarz
    tarz over 11 years ago
    Great improvements. Now, where do I get one of these?
  • tarz
