Raspberry Pi
Raspberry Pi
Documents Assembled Gertboard for Raspberry Pi
  • Author Author: joeman
  • Date Created: 17 Jan 2013 5:05 PM Date Created
  • Last Updated Last Updated: 10 May 2021 8:50 PM
  • Views 15372 views
  • Comments 43 comments
Buy NowBuy NowFeaturesUser ManualSoftwareApplicationsOther Raspberry Pi Accessories
Overview
Gertboard is the ideal add-on for Raspberry Pi. Designed by Gert van Loo, it is a flexible experimenter board that plugs directly into your Raspberry Pi, and out into the physical world, allowing you to detect and respond to external physical events. Detect and output analogue voltages. Drive powerful motors. Detect switch presses. Illuminate LEDs and drive relays. Jumper cables allow you to hook up different parts of the circuit in many different ways, allowing total flexibility. All controlled by your own Raspberry Pi.
Features:
  • Plugs directly onto Raspberry Pi GPIO socket
  • Motor controller, capable controlling a motor bi-directionally, delivering 18V and 2A maximum
  • Dual-channel D-to-A converter, 8-bit
  • Dual-channel  A-to-D converter, 10-bit
  • Onboard Atmel ATmega328ATmega328 MCU for running off-board programmes which are written, compiled and uploaded to Gertboard from Raspberry Pi
  • 6 x open collector outputs
  • 12 x LED indicators
  • 3 x momentary push switches
  • 10 x strap cables included
  • 18 x jumpers included
  • Software and manuals available to operate and learn how to use Gertboard
Back to top
Key Applications
  • Experimentation
  • Home burglar alarm
  • Motor control
  • Sensor detection and control
  • Educational applications
Back to top
  • raspberry
  • pi
  • raspberry_pi
  • for
  • assembled
  • gertboard
  • dracocarathyr
    dracocarathyr over 11 years ago
    Does anyone know if there is an updated version for the Pi 2?
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to dracocarathyr
    Is it necessary for an update, the GPIO pins used I believe are still compatible with the PI2 so unless there planning on adding more IO to the board it should be ok. I have not tested to see if the connector gets in the way but I will tonight
  • dracocarathyr
    dracocarathyr over 11 years ago in reply to Robert Peter Oakes
    If you would check the compatability, I would appreciate it.
    Just to let you know, I have not forgotten, just very busy and have to still get this done
    Soon I promise
    Peter
  • dracocarathyr
    I understand. There is no rush right now
  • dracocarathyr
