    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
Raspberry Pi
Raspberry Pi
Documents Raspberry Pi 3 Model B Plus (B+) Technical Specifications
Raspberry Pi requires membership for participation - click to join
  • Author Author: cstanton
  • Date Created: 9 Mar 2018 2:02 AM Date Created
  • Last Updated Last Updated: 16 May 2018 2:50 PM
  • Views 6677 views
  • Likes 20 likes
  • Comments 16 comments
NEW! Raspberry Pi 3 Model B+
Technical Specifications | Compliance Documentation | GPIO Pin Out | Unboxing Video | Benchmark Tests | Frequently Asked Questions | Comparison Chart | Pi PoE Hat | Pi Accessories | Pi Projects
Watch the Tech Specs Intro video of the Pi 3 Model B+:
Watch Video
Buy NowBuy Now
*US Customers: We'll update you when more stock is available. For now, please back order your unit to reserve your Rasperry Pi!
Key Improvements from Pi 3 Model B to Pi 3 Model B+:
image Improved compatibility for network booting and new support for Power over Ethernet
image Processor speed has increased from 1.2Ghz on Pi 3 to 1.4Ghz, with improved thermal management
image New dual band wireless LAN chip, 2.4Ghz and 5Ghz with embedded antenna
image Bluetooth 4.2 Low Energy onboard
image Faster onboard Ethernet, up to 300mbps!
Other Technical Specification:
image 40 pin extended GPIO
image 4 x USB 2 ports
image 4 pole Stereo output and Composite video port
image Full size HDMI output
image CSI camera port for connecting the Raspberry Pi CameraRaspberry Pi Camera
image DSI display port for connecting the Raspberry Pi Touch Screen DisplayRaspberry Pi Touch Screen Display
image microSD port for loading your operating system and storing data, up to 64GB tested
image Upgraded switched Micro USB power source (now supports up to 2.5 Amps)
image The same form factor as previous Raspberry Pi boards!
  • technical_specifications
  • raspberry_pi_3_b_plus
  • raspberry pi 3 model b plus (b+) tech specs
  • hoopsurfer
    hoopsurfer over 5 years ago +2
    Model B+ Test Installs on Pi Desktop Case with Different SSDs After getting my hands on a Model B+, I was able to test it with the Pi Desktop Case using different SSDs. The B+ supports Boot from USB by…
  • cstanton
    cstanton over 5 years ago in reply to darthkegraider +1
    Yes. With the faster ethernet you're talking a potential max of 300mbps, in some real world benchmarks I was getting 140mbps from ethernet to usb storage ( A Comprehensive Raspberry Pi 3 Model B Plus …
  • snidhi
    snidhi over 5 years ago +1
    The comparison chart is very interesting. Finally I am motivated to get the Raspberry Pi 3 B+
  • ninjatrent
    ninjatrent over 5 years ago
    " New dual band wireless LAN chip, 2.4Ghz and 5Ghz with embedded antenna".
    I have 2.4G and 5G bands on my network. The 5G band is not detected by the B+. I'm using most recent, up to date Raspbian Stretch image. Is the 5Ghz band a feature that is not yet supported?
  • ninjatrent
  • ntewinkel
    ntewinkel over 5 years ago in reply to ninjatrent
    I'm finding the Pi3 Wifi in general to be very unreliable so far. I'm not far from the WiFi hub either.
    I wish they would add an external antenna option (like that little button-snap type the Arduino Yun has).
    -Nico
  • Problemchild
    Problemchild over 5 years ago in reply to ntewinkel
    Hey Nico,must of been typing at the same time . Yes I just find the WIFI unreliable expecially in my office where there loads of tech busineses and no doubt a high noise floor. Best to use an external usb device, even those tiny little ones!
  • ntewinkel
    ntewinkel over 5 years ago in reply to Problemchild
    Right! I've been using those on my pi1 and pi2 and those have been behaving really well. Pi1 has one of those cheapo little things off EBay even. (Pi2 has a WiPi)
    -Nico
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
