    Members
    • Experts & Guidance
    • Avnet Boards Community
    • Or choose another store...
Raspberry Pi
Raspberry Pi
Documents Raspberry Pi 3 Model B Plus (B+) Technical Specifications
Raspberry Pi requires membership for participation - click to join
  • Author Author: cstanton
  • Date Created: 9 Mar 2018 2:02 AM Date Created
  • Last Updated Last Updated: 16 May 2018 2:50 PM
  • Views 6663 views
  • Likes 20 likes
  • Comments 16 comments
NEW! Raspberry Pi 3 Model B+
Technical Specifications | Compliance Documentation | GPIO Pin Out | Unboxing Video | Benchmark Tests | Frequently Asked Questions | Comparison Chart | Pi PoE Hat | Pi Accessories | Pi Projects
Watch the Tech Specs Intro video of the Pi 3 Model B+:
Watch Video
Buy NowBuy Now
*US Customers: We'll update you when more stock is available. For now, please back order your unit to reserve your Rasperry Pi!
Key Improvements from Pi 3 Model B to Pi 3 Model B+:
image Improved compatibility for network booting and new support for Power over Ethernet
image Processor speed has increased from 1.2Ghz on Pi 3 to 1.4Ghz, with improved thermal management
image New dual band wireless LAN chip, 2.4Ghz and 5Ghz with embedded antenna
image Bluetooth 4.2 Low Energy onboard
image Faster onboard Ethernet, up to 300mbps!
Other Technical Specification:
image 40 pin extended GPIO
image 4 x USB 2 ports
image 4 pole Stereo output and Composite video port
image Full size HDMI output
image CSI camera port for connecting the Raspberry Pi CameraRaspberry Pi Camera
image DSI display port for connecting the Raspberry Pi Touch Screen DisplayRaspberry Pi Touch Screen Display
image microSD port for loading your operating system and storing data, up to 64GB tested
image Upgraded switched Micro USB power source (now supports up to 2.5 Amps)
image The same form factor as previous Raspberry Pi boards!
  • technical_specifications
  • raspberry_pi_3_b_plus
  • raspberry pi 3 model b plus (b+) tech specs
  • hoopsurfer
    hoopsurfer over 5 years ago +2
    Model B+ Test Installs on Pi Desktop Case with Different SSDs After getting my hands on a Model B+, I was able to test it with the Pi Desktop Case using different SSDs. The B+ supports Boot from USB by…
  • cstanton
    cstanton over 5 years ago in reply to darthkegraider +1
    Yes. With the faster ethernet you're talking a potential max of 300mbps, in some real world benchmarks I was getting 140mbps from ethernet to usb storage ( A Comprehensive Raspberry Pi 3 Model B Plus …
  • snidhi
    snidhi over 5 years ago +1
    The comparison chart is very interesting. Finally I am motivated to get the Raspberry Pi 3 B+
  • jacksplace
    jacksplace over 5 years ago
    I just got my B+, plug it in with a 5V plug and nothing happens. Shows a rainbow screen with a electric bolt at the top right corner. The red light flashes and that is it. I have the B and it works fine, same power plug. What could be the problem....
    shabaz over 5 years ago in reply to jacksplace
    Hi John,
    Please see the graph here:
    https://raspi.tv/2018/how-much-power-does-raspberry-pi-3b-use-power-measurements
    Depending on what PSU and cable you're using, it may need upgrading. The official Pi PSU should work.
  • dhassall@zianet.com
    dhassall@zianet.com over 5 years ago in reply to shabaz
    Thanks for the bad news.   For me the extra power requirements is very disappointing and for my project a show stopper.   So I need to go find some replacement Raspberry Pi 3B that fit my system and will work.   For my projects the 3B+ is a killer.   Too bad the geniuses that keep figuring the upgrades to a perfectly operating unit suddenly makes it totally unusable.  I don't understand the hype for the new 3B+ downplayed the extra power requirement.  The only improvement that would even make a very minor improvement to what I am doing is the minor increase in processing speed to 1.4GB.   I probably wouldn't even notice it as the Pi is Loafing doing what I have it doing now.   So, I am off to find some Raspberry PI 3B's to buy and throw these 3B+ in the Junk box.  I am Very Disappointed with the only thing I could get out of them was a multicolored screen and 4 long and 4 short red flashes of the power LED.  To bad the Raspberry PI utility is being ruined by UPGRADES that don't really improve it's utility.
    73 Dave WA5DJJ
    shabaz over 5 years ago in reply to dhassall@zianet.com
    Hi David,
    I agree, if you don't need the features/deltas then it's better to just purchase a Pi 3B instead of 3B+, and save some power in the process.
    A couple of months back we needed some more Pi's and went with 3B too, since sometimes it's better to go with what you know, rather than take on a new platform, power requirements, etc. However it's been several months now, and the 3B+ is more mature now, so I might reconsider it for the next purchase.
  • Problemchild
    Problemchild over 5 years ago in reply to dhassall@zianet.com
    is the extra power requirement solely down to the extra clock rate ...in which case you could under clock the cpu to get thepower your application demands
  • Problemchild
An Avnet Company © 2023 Premier Farnell Limited. All Rights Reserved.
