Raspberry Pi
Raspberry Pi
Documents Professional and Industrial Users of Raspberry Pi
  • Author Author: e14phil
  • Date Created: 16 Mar 2018 1:37 PM Date Created
  • Last Updated Last Updated: 16 Mar 2018 1:37 PM
  • Views 1103 views
Hi all!
I would love to hear your thoughts on using the Raspberry Pi 3 B+ in Professional and Industrial Use Cases.
The New Raspberry Pi 3 B+ has been intentionally built to make it easier/less expensive to be signed off with simplified Radio Module Conformity and the new PoE hat on its way, allowing for headless operation, Power over Ethernet and, Boot over ether net.
Do you use your Raspberry Pi in an industrial use (IIoT)?
Have you built the Raspberry Pi into a product? Was it easy to do?
What are your thoughts on Raspberry Pi's efforts to reduce time and money making the RF area meet Modular certification?
If you have not? What is deterring you?
New RF  Conformity documentation:
https://www.raspberrypi.org/documentation/hardware/raspberrypi/conformity.md
Interview with Ben and Roger
Discussing the new board and benefits of the RF module and PoE.
Eben Upton and Roger Thornton Interview: Raspberry Pi 3 Model B+
PoE Hat (Pre-order available now):
Raspberry Pi 3 Model B Plus (B+) PoE (Power Over Ethernet) Hat
The official Power over Ethernet (PoE) add-on board for the Raspberry Pi 3 Model B+! Use this HAT to power a Raspberry Pi via an Ethernet cable, removing the need for a separate power supply, an ideal solution for embedded and IoT projects. For Raspberry Pi 3 Model B+ and onwards, an 802.3af compliant POE injector, switch, or router device is required (not included).
  • Power over Ethernet 802.3af compliant
  • Power over Ethernet Boot (PXE Boot)
  • Class 2 device
  • Fully isolate Switched-Mode Power Supply (SMPS)
  • 36-56V Input Voltage
  • 5V Output Voltage
  • Supplies up to 2.5A
  • Fan Control
  • Plug-and-play compatibility with Raspberry Pi 3 Model B+
Best of all, it fits within the official Raspberry Pi Case!
This document was generated from the following discussion: Professional and Industrial Users of Raspberry Pi
    DAB over 7 years ago +2
    Hi Phil, I am working with a group that is looking at using the RPi to trigger cameras based upon GPS position for aerial data collection. So I think the RPi has a lot of potential for industrial applications…
  • Robert Peter Oakes
    Robert Peter Oakes over 7 years ago +2
    I would be sure the PXE boot option is not dependent on the POE, if the unit is locally powered I dont see any reason the PXE wont still work, even without the header. See https://en.wikipedia.org/wiki…
    Hi Phil,
    So I think the RPi has a lot of potential for industrial applications, it will just take some time and work to produce products that take it into account.
    Biggest problem is the Not Invented Here syndrome.
    Hi Phil,
