Raspberry Pi
Raspberry Pi
Documents Raspberry Pi PoE+ HAT - The New PoE Hat for Raspberry Pi
  • Author Author: e14phil
  • Date Created: 19 May 2021 2:21 PM Date Created
  • Last Updated Last Updated: 25 May 2021 8:29 AM
  • Views 2297 views
MORE POWER!
Today we’re announcing the next generation of our Power over Ethernet (PoE) HAT. Compared to its predecessor, the Raspberry Pi PoE+ HAT delivers more power, implementing the 802.3at PoE+ standard; and it runs cooler, thanks to various design improvements. Best of all, we’ve been able to keep the original affordable price of $20.
The original PoE HAT implements the 802.3af standard, and can deliver a guaranteed minimum of 13W to the Raspberry Pi. This is enough to power a Raspberry Pi 4 at maximum load, but not quite enough to power the hungriest USB peripherals at the same time.
The PoE+ HAT implements the 802.3at standard. When used with a compatible switch or injector this means it can deliver up to 25W, as you can see from this comparison table.
PoE HATPoE+ HAT
Standards supported802.3af802.3af, 802.3at
Output voltage5V5V
Maximum output current2.5A5A
Maximum power15.4W25.5W
FanYesYes
Current senseNoYes
Transformer designWire-woundPlanar
PCB4 layers, 2oz copper4 layers, 2oz copper
Price$20$20
Compatible withRaspberry Pi 3B+, 4BRaspberry Pi 3B+, 4B
The new components:
A New Diode Rectifier -
The Raspberry Pi Foundation have replaced the existing diode rectifier with what they are calling an "Ideal diode".
A New Transformer - Bourns Planar Transformer
A very interesting almost flat transformer which uses PCB traces as windings for the Transformer its self!
All in all a wonderful and rounded upgrade with some great real world problem solving!
What would you do with the new PoE Hat?
  • raspberry pi pico
  • poe hat
  • raspberrypi
  • poe
  • raspberry pi accessories
  • ctim
    ctim over 4 years ago +2
    This Pi PoE+ Hat says its for a Pi3 when you go to purchase, will it work for Pi4?
  • ctim
    ctim over 4 years ago in reply to kmikemoo +2
    Thanks Mike.
  • kmikemoo
    kmikemoo over 4 years ago +1
    Love that transformer! Looks like I will be upgrading the POE hat for my PicoLog data logger.
  • ctim
  • ctim
  • kmikemoo
    kmikemoo over 4 years ago in reply to ctim
    ctim  According to Adafruit... Yes.  It will work with the Pi4.
  • ctim
    Thanks Mike.
