    • Avnet Boards Community
RoadTests & Reviews
RoadTests & Reviews
Blog MSP430FR4133 Launchpad with Custom BoosterPack in Action - appendix
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Author Author: tomaja
  • Date Created: 6 Jan 2016 1:15 PM Date Created
  • Views 526 views
  • msp430fr4133
  • illuminated_multirotor
  • boosterpack
  • ledroadtestplus
  • energia
  • launchpad
tomaja
tomaja
6 Jan 2016
Related posts:
Kit unboxing - LED RoadTest
Introduction to Bluetooth Low Energy Light Development Kit - CC2540TDK-LIGHT
Android Support for TI's BLE LED Control
MSP430FR4133 Launchpad - Magnetic North Visualisation
Illuminated Tricopter Upgrade - Adding an Addressable LED Ring
MSP430FR4133 BoosterPack for Illuminated Tricopter
Bookshelf Lights Using TI's CC2450 BLE LED Modules
MSP430FR4133 Launchpad with Custom BoosterPack update
Adding Remotely Controlled Headlights to Tricopter
Issues when running LaunchPad from BoosterPack power
I've been powering the MSP430FR4133 LaunchPad from USB for a while and life was beautiful image Then, I switched to using the BoosterPack to power all the components and here's where the trouble starts. LP started working sporadically, I could never guarantee that code will start executing. Then I started debugging the booster back since I assumed it's something I did wrong. I even decided to use a more powerful 3.3 voltage regulator (TI's LM1117-3.3) and had to etch another PCB to fit the different footprint image
However, this didn't help. So I continued debugging and at some point I decided to remove all the jumpers from the LP (not only the recommended ones - GND, 5V and 3.3V) - And that was it! It seems that when you have the programming jumpers connected LP will start at random. This is what happens with Energia, at least. CCS might behave better since it's using a different driver for debugger.
Anyway, this was good enough for me but at some point I got tired from removing 7 jumpers and putting them back on every time I flash and test an updated Energia sketch.
Today I decided to use a bit of hot glue and a piece of board to make single block of jumpers that are easy to remove and put back onto the LP.
Cheers!
    shabaz over 9 years ago +1
    That's a neat trick! I'll have to remember that : ) It is irritating when some boards have so many jumpers (Raspberry Pi GertX boards are guilty of that) that it becomes hard to remember what does what…
    mcb1 over 9 years ago +1
    Excellent trick. Well done. Mark
    It is irritating when some boards have so many jumpers (Raspberry Pi GertX boards are guilty of that) that it becomes hard to remember what does what!
