      • Japan
      • Vietnam
RoadTests & Reviews
RoadTests & Reviews
Review Blogs Multicomp Pro Non-Contact Voltage Tester vs. Christmas Lights
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Author Author: kmikemoo
  • Date Created: 7 Jan 2021 5:30 PM Date Created
  • Views 4390 views
  • Likes 12 likes
  • Comments 17 comments
  • tools
  • tools_and_test_equipment
kmikemoo
kmikemoo
7 Jan 2021
To a man with a hammer, everything looks a nail.          To a man with a non-contact voltage tester... anything energized needs to be checked.
As part of roadtesting the Multicomp Pro Non-Contact Voltage Tester, I couldn't resist trying it out in a few non-roadtest applications.  Here is one.
Yes.  The string is repaired, ready for next year.
  • colporteur
    colporteur over 5 years ago +4
    I like the application of the tool. Way to think out of the box. My two test ideas for the RoadTest was detecting AC wires between wall studs ( I seem to recall that was tried) testing model railroad DCC…
  • 14rhb
    14rhb over 5 years ago in reply to kmikemoo +4
    Just hanging a picture required a masonry bit. The worst locations in UK houses (not for a picture, but the curtain rail fixings) were very often above windows where reinforced concrete was often used…
  • Andrew J
    Andrew J over 5 years ago +3
    Nice one, and a great idea. Are those 110V (US?) strings? I looked at a couple of strings I have. One uses a 240V/24V AC/AC converter and one seems 240Vac all the way to the lights built onto the Christmas…
  • kmikemoo
    kmikemoo over 3 years ago
    I had to break the non-contact voltage tester out again this pre-holiday season.  Eight lights in half of a 100-light string had flamed out.  They are supposed to fail shorted but we all know that this does not always happen.  It worked like a charm - again.  I'm beginning to hate fairy lights just a little less - now that they are easier to fix. Laughing
  • kmikemoo
    kmikemoo over 5 years ago in reply to 14rhb
    14rhb  Unfortunately, I still use the old school hammer drill and bits.  I don't drill into masonry very often so I can't bring myself to upgrade.  Great question though.  It really got me thinking because, like you said, I've destroyed a lot of masonry bits in my day.
  • Andrew J
    Andrew J over 5 years ago in reply to colporteur
    It ought to as it doesn't need a completed circuit to work.  At low voltages it needs high frequencies - at 14V, >= 100Hz would be best so in reality not that high!  You could pump any varying signal through the track I would think.  Unfortunately, I don't have any train sets, or Scalextric, to try it out.
    beacon_dave over 5 years ago in reply to 14rhb
    "...Do you know if there is a proper name for them?..."
    Rawlplug jumper chisel or Rawlplug tool I think.
    "...although the hitting end did eventually round it over..."
    I think there was an outer handle available for them to prevent mushrooming of the struck end and prolonging the life of the chisel but perhaps seldom used.
  • 14rhb
    14rhb over 5 years ago in reply to Andrew J
    Still handy to have one. They are good for other tasks e.g. to break a small hole in a concrete pad without damaging a large area by chain-drilling around the section to remove. Or like I mentioned, making a water feature where the pre-drilled stone was £45 at the garden center and a bigger non-drilled one was only £5.
    My SDS has a rotation stop so I've got a concrete breaking chisel to go with it. The trouble is I get a bit to ambitious forgetting this is only a DIY tool and not a road-breaker, and often get the chisel stuck in the ground image
