After completing the Multicomp Pro Non-Contact Voltage Tester - Review, I asked myself "Why don't I use this type of tool more?" Then I started thinking of some of the events that distracted me along the way. This blog just might be my version of the bloopers reel.
Does a good ground really matter?
I know it does, but how much? I call this the Flamingo Testing Method. Stand on the sneaker. Measure. Stand on the bare foot. Measure. Hope Amazon finally delivers the grounding strap today. Repeat.
This was a preliminary test. The ones used in the roadtest didn't involve this method.
Everything is Hot
Generator controller with 12VDC from an AC adapter.
Label maker.
Battery Powered Stick Vacuum.
Ground Wire
I'm not tough enough to hold onto an energized conductor. I still haven't sorted this out. There is no measured voltage on the ground wire (millivolts that do not fluctuate). Fluctuating millivolts would indicate an open. I tested the grounding (Earthing) circuit and it is in tact. 6" steel water line. No measurable drop in the bonding circuit.
This is why I don't use this type of tester more often.
At least it fails safe.
jc2048
Cancel
Vote Up
+3
Vote Down
Sign in to reply
More
Cancel
kmikemoo
in reply to jc2048
Cancel
Vote Up
+3
Vote Down
Sign in to reply
More
Cancel
Comment-
kmikemoo
in reply to jc2048
Cancel
Vote Up
+3
Vote Down
Sign in to reply
More
Cancel
