RoadTests & Reviews
RoadTests & Reviews
Review Blogs PYNQ-Z2 Dev Kit - CIFAR-10 Webcam continued....
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: ralphjy
  • Date Created: 14 Aug 2019 5:03 AM Date Created
  • Views 2265 views
  • Likes 8 likes
  • Comments 7 comments
  • RoadTest
  • pynqworkshpch
  • pynq-z2
  • cifar10
  • machine learning
ralphjy
ralphjy
14 Aug 2019
In the previous blog PYNQ-Z2 Dev Kit - CIFAR-10 Convolutional Neural Network , I verified the 3 hardware classifiers against the reference "deer" test image.  Now I'm going to see how the classifiers perform with captured webcam images.  I expect the performance will be degraded because the webcam will produce lower quality images due to issues like image brightness and focus.  CIFAR-10 has a small training set (5000 images per class), so I'm going to use a solid background to help keep the image simple.  Intuitively, I would expect that with higher quantization level the classification accuracy would improve.
I decided that since CIFAR-10 has transportation classes (automobile, truck, ship, airplane) that I would try to classify a few Matchbox vehicles that had escaped being recycled.
Here is my test setup.  I was a bit disappointed in the auto-focus and auto-exposure of the webcam, but I haven't figured out whether I can manually control this particular camera with OpenCV.
First try is the firetruck.  I expected this one to be easy, but only the W2A2 classifier got it right.
Second try is the convertible.  All the classifiers thought this was an airplane.  I'm assuming that the odd colors may have been confusing.
Third try is a car that I thought should be easy but interestingly the classifiers with higher quantization very clearly classified it as an airplane and the binary classifier thought it was a ship.
As a head check I grabbed one of the CIFAR-10 test images and it correctly classified with increasing accuracy as the quantization increased.
At this point I'm confused as to the primary cause of the poor classification of the webcam images.  Is it the image quality or the actual image.  I suspect it is both.
I noticed that the example notebook includes a sample webcam capture of an elk figurine which should classify as a "deer".
I would consider this a much harder image to classify because of the background.  It's interesting that in two of the classifiers that "airplane" and "deer" are closely ranked.  I'm getting the impression that CIFAR-10 trained networks are a good educational tool, but would not work well in the real world.  I'm going to move on to look at other neural network examples.
    beacon_dave over 6 years ago in reply to genebren +2
    Just wondering if the solid background and the loose framing isn't helping matters here ? Perhaps try adding some whitespace around the sports car training image and see if it too starts to fly...
  • ralphjy
    ralphjy over 6 years ago in reply to beacon_dave +2
    Okay, I did as you suggested and now it indeed does fly. Something tells me you've done this before . It does suggest that this network would not have worked as I would have tried to use it.
    dubbie over 6 years ago +2
    It is one of the strange (?) things about using Artificial Neural Networks (ANN), particularly when using image systems or other data that is viewed by humans, is that they use all the data. When a human…
    genebren over 6 years ago
    Ralph,
    Interesting results.  The models really seem to be heavily weighted to call everything airplanes (even a plastic elk).  Image quality, likeness of image to learning images and many other minor details seem to influence the item classification.
    Great work on digging in and comparing these classifiers.
    Gene
  • ralphjy
    An easy enough experiment to try.  Did not yield though.  Still favors airplane although now the binary classifier thinks it's a cat image.
    Sorry misinterpreted your comment.  Let me give it another go with the training image....
  • ralphjy
    Okay, I did as you suggested and now it indeed does fly.  Something tells me you've done this before image.   It does suggest that this network would not have worked as I would have tried to use it.
