This is the fifth instalment in a series of blog posts to support a RoadTest Review of the ACCESS:bit for micro:bit. The review is being conducted by a student from a high school computer club. Details on how the RoadTest is being conducted can be found here RoadTest Support: ACCESS:bit for micro:bit The Application
Our RoadTest review team is happy to report, the ACCESS:bit is working. The student was experiencing some problems detailed in the last blog posting RoadTest Support: ACCESS:bit for micro:bit Troubleshooting . The issues have been resolved and the unit now works as described in the documentation (the correct document that is).
I can’t stress how important it was to have the documentation that reflected the equipment used. Assuming the documents provided from the RoadTest site were accurate and failing to confirm the assumption created a path that didn't lead to success.
There doesn’t appear to have been any issues with the equipment itself. A lack of experience, incorrect documentation and not following instructions verbatim were factors in the student not getting the device working initially.
On reflection, the Coaches decision to allow the student to work independently and continue to keep a hands-off approach may have placed an undue burden on the student to succeed. The student worked out the issues and in the end got the device working.
Using the correct documentation and following the instructions as provided in the document enabled the student to get the unit working. The student struggled unnecessarily. This struggle would have been minimized if the experience had of stepped in. Hindsight is always 20/20.
Doing the same thing over and over again and getting the wrong results, is a pattern the most experience person will fall victim to. “It has to work” are words I have uttered many times. Trying the same thing again to get the same result is not uncommon.
The instructions, “I want you to use the code as written, do not change a thing”, was a lesson that had to be learned. The statement, "But it should work", fell on deaf ears. Do it as the document says and let me know if it works. Guess what. it did.
This concludes the blog post in support of the RoadTest. The student and Coach have a final meeting pending to discuss the preparation of the RoadTest Review document.
kmikemoo
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
Comment-
kmikemoo
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
