    • Avnet Boards Community
RoadTests & Reviews
RoadTests & Reviews
Blog TI and Würth Elektronik LED RoadTest+ - Circuit Crafting - 8/10
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Author Author: tonyboubady
  • Date Created: 10 Jan 2016 2:15 PM Date Created
  • Views 686 views
  • Comments 11 comments
  • RoadTest
  • ledroadtestplus
  • würth
  • we
  • elektronik
  • texas_instruments
  • ti
tonyboubady
tonyboubady
10 Jan 2016
Update: I am working on the soldering WE's SMD LEDs with my tricks and ideas. You know what? it really looks cool and works great...but... I don't think I can do the thermal protection with the board I have etched, it seems super hard and as well the amount of LEDs with thermal holes seems almost snap off point of the board, too close and board is getting weak...My design could work with professional PCB with 3 layers. I am going to finish this project up for demonstration purpose only...will update on next post...
Hello, here I am again with some update image
I have managed to finish the etching process today, successfully... and I am happy about it. I started with printing my circuit design with laser print and I am not using any glossy paper, it was a quite a story that I can't take laser print with glossy paper here, so I have figured out a way to do it with regular A4 paper and some tricks image
This is my successful toner transfer to copper clad board...
I had to do some adjustment with permanent marker pen (Sharpie), yeah! that's how we call it here in India.
Now it's time to etch the board with Ferric Chloride - FeCl3 ... and this is the result.
It's not the perfect one but it does the job...
I am happy about the result... even less than half a millimetre space has been etched, really cool... the next process is soldering the SMD LEDs, WOW!!! but I have some IDEA to do it without using hot air gun, soldier paste with oven etc etc... image. I will post my process in next coming days.
  • tomaja
    tomaja over 9 years ago in reply to shabaz +3
    Hi shabaz , Do you think he could use solder just to reach the bottom side of the board and then thermal paste to connect to heatsink? (I originally planned to do that, but later I found suitable Aluminium…
    shabaz over 9 years ago +2
    Hi Antony, I'd hate for you to solder on all those LEDs, and then find out, but have you checked what heatsinking requirements are needed? If these are LEDs with 350mA or higher current consumption, then…
    shabaz over 9 years ago in reply to tomaja +2
    Hi tomaja Interesting idea, it may be possible, if it is filled with solder from the underside somehow and then flipped over and sanded/polished flat. There is a product which would have been suitable…
    dougw over 9 years ago
    Hi Antony,
    Aesthetically a very nice looking design and good work on successfully etching the traces. As you have realized, this design imposes significant limitations on how much current can be used, but it will still look very cool.
    Here are some references that might help figure out how much power your design can handle:
    http://focus.ti.com/download/trng/docs/seminar/Topic%2010%20-%20Thermal%20Design%20Consideration%20for%20Surface%20Mount…
    Thermal Vias – A Packaging Engineer’s Best Friend « Electronics Cooling Magazine – Focused on Thermal Management, TIMs…
    It takes a lot of work to accurately figure out ,but you can quickly get a rough estimate for how much power your design can handle. If this is satisfactory, you can do a test to see exactly how much power is possible. Simply populate the card and slowly increase current until the LEDs get to a maximum safe temperature.
    Doug
    Hi Antony,
    Doug
  • tonyboubady
    tonyboubady over 9 years ago in reply to dougw
    Nice resources, thank you...Yes, I have to learn a lot...I have doubts about the maximum current flow of my design too, my copper clad thickness is too thin and I have gradual 1.016 mm trace width, But anyhow I will proceed with this image ...and yes, I will take your advice and test my LEDs as you said...
