The TDC1000-TDC7200EVMTDC1000-TDC7200EVM evaluation module has 4 main parts The TDC1000 analog front-end and a pre-programmed MSP430 microcontroller on the board, a 1MHz Piezo Ceramic sensor that plugs into the board and a GUI client for on your PC.
In this blog I'm attaching the Piezo transponder to the "liquid under test" container.
Follow the Guide
This exercise isn't difficult. There's an excellent step-by-step instructable available on TI's web:
http://www.ti.com/lit/pdf/snaa266
What do you need?
- The sensor from the evaluation kit.
- CYA Latex Glue and activator
- Hot glue gun
- Container for the liquid (I used a plexi box that contained pinterest pins)
- Sandpaper, grid 400
- Hot air gun
- Alcohol (I used isopropanol)
What do you need to do?
All easy steps.
- Sand the part of the container where you want to attach the sensor, and clean that area up with alcohol.
- Dry with hot air gun.
- Apply CYA glue and activator, as specified on your-glue-of-choice's instructions.
My glue, Loctite Super Glue-3, suggested to also sand down the sensor, because the surface is metal.
I had to apply activator first, on both surfaces and wait a minute
Then I had to apply glue on one surface only. I applied it on the sensor.
Then I had to put the sensor on the container and apply light pressure for a minute.
- Clean up any activator residue with alcohol.
- Apply hot glue around the sensor.
- Burry the sensor in hot glue.
- Cool down with hot air gun on minimum temperature setting.
It's a fun activity for a rainy day.The whole exercise doesn't take more than an hour. I spent more time shopping for the ingredients.
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
in reply to DAB
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
tomaja
in reply to Jan Cumps
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
in reply to tomaja
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
Comment-
in reply to tomaja
Cancel
Vote Up
+1
Vote Down
Sign in to reply
More
Cancel
