      • Japan
      • Vietnam
RoadTests & Reviews
RoadTests & Reviews
Review Blogs TI Ultrasonic Sensor - Prepping the Transponder
  • Blogs
  • RoadTest Forum
  • RoadTests
  • Reviews
  • Date Created: 16 Dec 2015 8:28 PM Date Created
  • Views 1974 views
  • Comments 7 comments
  • RoadTest
  • tdc1000-tdc7200evm
  • ultrasonic_sensor
  • steminc
  • texas_instruments
  • tdc1000
16 Dec 2015
The  TDC1000-TDC7200EVMTDC1000-TDC7200EVM evaluation module has 4 main parts
The TDC1000 analog front-end and a pre-programmed MSP430 microcontroller on the board, a 1MHz Piezo Ceramic sensor that plugs into the board and a GUI client for on your PC.
In this blog I'm attaching the Piezo transponder to the "liquid under test" container.
Follow the Guide
This exercise isn't difficult. There's an excellent step-by-step instructable available on TI's web:
http://www.ti.com/lit/pdf/snaa266
What do you need?
  • The sensor from the evaluation kit.
  • CYA Latex Glue and activator
  • Hot glue gun
  • Container for the liquid (I used a plexi box that contained pinterest pins)
  • Sandpaper, grid 400
  • Hot air gun
  • Alcohol (I used isopropanol)
What do you need to do?
All easy steps.
  • Sand the part of the container where you want to attach the sensor, and clean that area up with alcohol.
  • Dry with hot air gun.
  • Apply CYA glue and activator, as specified on your-glue-of-choice's instructions.
My glue, Loctite Super Glue-3, suggested to also sand down the sensor, because the surface is metal.
I had to apply activator first, on both surfaces and wait a minute
Then I had to apply glue on one surface only. I applied it on the sensor.
Then I had to put the sensor on the container and apply light pressure for a minute.
  • Clean up any activator residue with alcohol.
  • Apply hot glue around the sensor.
  • Burry the sensor in hot glue.
  • Cool down with hot air gun on minimum temperature setting.
It's a fun activity for a rainy day.The whole exercise doesn't take more than an hour. I spent more time shopping for the ingredients.
Related Posts
RoadTest: Unboxing the TI Ultrasonic Sensing evaluation module
TI Ultrasonic Sensor - A Very First Trial of the GUI
TI Ultrasonic Sensor - First Measurements
TI Ultrasonic Sensor - Set the Parameters for Level Measurement and Content Identification
TI Ultrasonic Sensor - Show 3 Signals on a 2 Channel Oscilloscope (RIGOL DS1052E)
TI Ultrasonic Sensor - Liquid Identification and Concentration
TI Ultrasonic Sensor - Create a KiCad Part for the Sensor IC with KiPart
TI Ultrasonic Sensor - SPI Traffic Snooping
TI Ultrasonic Sensor - RoadTest Review
    DAB over 9 years ago +1
    Nice post. Sometimes people forget that sensor contact is very important for accurate readings. DAB
    Jan Cumps over 9 years ago in reply to DAB +1
    Yes, certainly in this case where the method of measuring is to detect the reflection of the signal caused by the border between two materials (e.g.: liquid and air). The speed of sound is a driving factor…
    Jan Cumps over 9 years ago in reply to tomaja +1
    I don't know. My guess is that the sensor ignores the first boundary it meets (container -> fluid) and measures the second boundary (fluid -> Gas/Air; fluid -> second container wall). Then again, This…
    Nice post.
    Nice post.
    Yes, certainly in this case where the method of measuring is to detect the reflection of the signal caused by the border between two materials (e.g.: liquid and air). The speed of sound is a driving factor in the measurement.  A dirty mount between sensor and container makes those measurements so much more difficult.
  • tomaja
    tomaja over 9 years ago in reply to Jan Cumps
    How different reservoir bottom thickness affect the readings? Can you calibrate the sensor to take into account different reservoir build materials and thicknesses?
    I don't know. My guess is that the sensor ignores the first boundary it meets (container -> fluid) and measures the second boundary (fluid -> Gas/Air; fluid -> second container wall). Then again, This is just a wild guess. I hope to learn more when reading datasheets and application notes.
  • tomaja
    Yeah, I assumed that first boundary is ignored (there's a minimum level you can set and discard this boundary),
    I was thinking that there could be some different offsets (for different reservoirs) in readings due to different delays through the bottom but that can probably also be ignored because delay through the bottom is probably neglectable due to high speed of sound through the rigid bodies.
    DAB over 9 years ago in reply to tomaja
    As I recall from the Webinar, the device does not begin looking for return signals until after the full chirp has been sent, so those early microseconds would not detect the initial sensor interface.
