Fluke 381 Clamp Meter
Table of contents
The road test for the Fluke 381 will follow a different format than usual. Here’s how you can participate:
  • Tell us how you would use the Fluke 381 Clamp Meter.  What kind of situations would you use it in?  How would you use the removable display and flexible current probe (iFlex)?  Would these new features change the way you work? Post a few sentences about how you would use the new meter.
    • Fluke will evaluate all the submissions and select the best responses
    • The selected winners will receive the new Fluke 381
    The Fluke 381 is the first clamp meter with a detachable, remote display and iFlex™ flexible current probe for easier, faster, safer measurements.
    The new Fluke 381 does everything you would expect from a clamp meter, and then lets you remove the display for even more flexibility. Now one technician can do jobs that used to require two people. Clamp the Fluke 381 around a conductor, remove the display and walk across the room to operate controls or remove protective equipment, all while watching real-time readings.
    The new iFlex flexible current probe (included) expands the measurement range to 2500 A ac while providing increased display flexibility, ability to measure awkward sized conductors and improved wire access.  Review the specs here.
    Have a Question About Test and Measurements
    Jim Newell
    Jim has worked for Fluke for a little over 31 years working in Manufacturing production and Quality assurance for the first 15 years. In the last 15 years he has focused on technical support as a Application Engineer for all of the Electrical Industrial products such as Handheld Oscilloscopes, Digital Mulitmeters and Power Quality Analyzers.  He enjoys the challenge of helping people and the famous saying the only dumb question is the one you didn’t ask are often joked about among his customers.
    Ask Jim a Question Here!
    RoadTest Reviews
    Comment List
    • Hi Ally,
      Got mine and I have already put up the review with my first thoughts about the meter. I should be able to follow up with some more input after the first few weeks of giving it a good thrashing!
      Cheers to Fluke and Element14 for the chance to review a great product.
    • Hi Ally,
