Weller 200W High Powered Digital Soldering Stations
Table of contents
This month, we are pleased to be giving away 3 Weller 200W High Powered Digital Soldering Stations – the WX1010, WX1012 and WX2020. The soldering stations have a temperature range of 150° F to 850° F, with an accuracy of +/- 17° F (9° C). The WX1012 station comes with a WXP65 Pencil which has a 0098" / 0.25mm Micro Tip. While the WX1010 an WX2020 both come with the WXP120 Pencil which has a .094" x 1.420" Reach Chisel Tip. The WX2020 has 2 soldering pencils and 2 iron stands. The stations are rated at an input of 120V.
The Weller WX system keeps your cost of ownership low with Intelligent power management to conserve energy and an exceptional degree of tool compatibility.
200 I   240W Total Power
Supports operation of one 200W tool or simultaneous   operation of two 120W tools (WX2 Only)
Viewable   From All Angles
Blue LED Backlighting to strengthen   visibility
Global   Language Support
Display multiple languages through menu selection
Intuitive   Interface
Six touch keys with radius finger guide for   turn-and-click navigation
Robust   Touch Screen
Patented, capacitive touch screen made of antistatic,   chemical and temperature resistant glass
Intelligent   Tool Recognition
Quick change connectors enable rapid tool   interchange
Multi-Purpose USB Port
Quick and localized software updates, parameter   configuration and data logging via USB stick
Intelligent   Accessory Management
Dual port configuration to manage fume extractors,   heating plates and programmable logic controllers
Comment List
Parents Comment Children
