Agilent’s 33500B Series waveform generators with exclusive Trueform signal generation technology offer more capability, fidelity and flexibility than traditional DDS generators. Easily generate the full range of signals you need to test your devices with confidence the signal generator is outputting the signals you expect with 12x less jitter and 5x less harmonic distortion. Take advantage of deep memory (1M points standard and optional 16M points) and waveform sequencing. Two-channel models allow you to use the channels independently or sync them in time, amplitude or both.
Q&A
What we would like to see in the road test?
Applications that take advantage of our Trueform technology. Some examples:
Applications that use multiple waveforms; sine waves, square waves, pulses, or custom waveforms.
Applications requiring low harmonic distortion sine waves
Applications that need pulses or square waves with low jitter.
Applications that need point-by-point arbitrary waveform capability – more accurate user defined waveforms.
Applications requiring deep memory or can take advantage of sequencing to create user defined waveforms.
An application that uses IQ signals or needs to output a data pair. E.g. A dual channel custom waveform
Are there certain application areas we would like folks working on?
We believe that most of the applications requiring Trueform Technology will be in: Research, Design, Product Development, Hardware Qualification, and Design Verification. It is less likely to find these applications in; Service, Installation, or Maintenance.
Reference Material
33500B Series Waveform Generator Data Sheet: click here
33500B Series Waveform Generator Quick Fact Sheet: click here
Testers will be selected on the basis of quality of applications: we expect a full and complete description of why you want to test this particular product.
Testers are required to produce a full, comprehensive and well thought out review within 2 months of receipt of the product.
Failure to provide this review within the above timescale will result in the enrolee being excluded from future Road Tests.
I received an email from UPS showing road test / sample as the description.
I had applied for several road-tests, but nothing recently and searching the forums I was unable to find my name anywhere so I had no choice but to track the package as it made its way across the pacific and be patient.
The wait was rewarded with Agilent 33522B !
Thanks for the opportunity to put this product its paces. I'll be doing my best to give a through and balanced review, but I have to say after only 30 minutes of inspection the impression is already very positive.
Former Member
Cancel
Up
0
Down
More
Cancel
Comment-
Former Member
Cancel
Up
0
Down
More
Cancel
