Enrollment closes in
Days 0 Hours 0 Mins 0 Secs 0
The xCORE-USB sliceKITxCORE-USB sliceKIT contains everything you need to start developing USB applications on xCORE multicore microcontrollers. The xCORE-USB sliceKITxCORE-USB sliceKIT features our 16 core High Speed USB device which delivers the deterministic, responsive processing required to handle a variety of peripheral interfaces, data processing and control tasks.
I have been working with the XMOS General Purpose Slice Kit for a couple months now. There is a learning curve involved due to the "xc" language extensions and the hybrid architecture XMOS uses. I spent…
Hi Linas,
The clock is 500MHz, and there is a pipeline type structure (in this case 4 stages), meaning that the throughput will vary (e.g. due to pipeline stalls or intentionally due to instructions or…
When you write question, you should supply all information.
FFT from 500Hz samplig can teke anywhere from 1ns to 10 years, question is sample size, or resolution of your FFT in Hz
With STM32F407 i was able…
audioboy140
Cancel
Up
0
Down
More
Cancel
Comment-
audioboy140
Cancel
Up
0
Down
More
Cancel
