Multicomp Pro MP750511 Arbitrary Waveform Generator
Table of contents
We need two Electronic Engineers to create a short video on how to use an arbitrary waveform generator in return we'll let you keep the test equipment for FREE.
About the Mulitcomp Pro RoadTest Fundamentals Series
This RoadTest is a part of our Fundamentals series where we are ask roadtesters to provide video demos of the featured product.
This time we’re looking for 2 electronic engineers to create a video on the fundamentals of using an arbitrary waveform generator, specifically the MP750511 US Waveform Generator.
Your RoadTest Application should include:
· The Key Benefits of Waveform Generator
· What  you have used a waveform generator for
· Tips & Tricks of Using a Waveform Generator in a short video
Your Video should:
· Be around 10 minutes in length
· Start with an introduction – introduce yourself and the product
· Talk about the types of tests you will be running
· Introduce the Device Under Test you will be using and show one to two examples of how to use the MP750511 to conduct those tests
· Wrap it up with recap – how does a Waveform Generator make tasks easier/possible? Explain how a Waveform Generator aids the design and troubleshooting process.
You do not need to do a standard RoadTest Review for this product.
Extra Credit:
Once you get the package delivered, please consider doing a 2-3 minute unboxing showing the product and “what’s in the box.”
Here are two examples of an unboxing:
Path to Programmable - MiniZed board overview and kit contents
LattePanda 3 Delta // Tech Highlight
Example Videos
Product Variants
  • MP750510 US, EU, UK plugs (depends on SKU number)
  • MP750511 US, EU, UK plugs (depends on SKU number)
  • MP750512 EU, UK plugs
  • MP750513 EU, UK plugs
Note: the product variant the roadtester receives will be based on their geographic location.
Multicomp Products
Click here to view other Multicomp Products.
Product Overview
Signal Generator Type: Arbitrary
No. of Channels: 2 Channel
Product Range: Multicomp Pro Waveform Generators
Bandwidth: 60MHz
Signal Generator Modulation: 3FSK, 4FSK, AM, ASK, BPSK, DSB-AM, FM, FSK, OSK, PM, PSK, PWM, QPSK, SUM
Manufacturer Warranty: 1 Year
Plug Type: US
Important Dates
Begin enrollment: January 10th, 2023
End enrollment: February 17th, 2023
Select RoadTesters: February 17th, 2023
Ship unit: Mar 2, 2023
Begin Recording: Mar 8 2023
Element14 follow up: Apr 8 2023
Post Videos by: May 6 2023
Terms and Conditions
Click here to view the Terms and Conditions
RoadTest Reviews
Comment List
  • Question for all:  It has crossed my mind that we may not be supplying everything a roadtester needs to test this product. So, what else do you need, if applicable?
    Randalll Scasny
    Roadtest Program Manager
  • Hi rscasny, looking at MP750511 datasheet seems to come only with a set of bnc to bnc cables (labelled Q9 cable). I think that adding a pair of bnc to alligator clip cables (or bnc-unterminated at least) will provide a lot more flexibility and added value for roadtesters without increasing too much overall cost for you.
    This is directly correlated to somebody like myself, with some basic instrumentation at home but without something "specific" like I mentioned above. Bnc to alligator in this case will make connection much easier to any kind of breadboard or prototype circuit.
  • We could add that to the roadtest package. Do you have any specific cables in mind. (Do you have a link?)
Comment Children
