Enroll to Review the Keysight Battery Emulator and Profiler E36731A
Table of contents
Optimize your IoT Devices with a Complete Battery Profiling and Emulation Solution!
What is a Battery Emulator? How is a battery emulator different from a DC power supply and an electronic load?
Battery emulators combine not only a DC power supply and an electronic load into one unit, they also emulate (or simulate) a battery to provide a good reference for testing charge levels. Emulating charge states can decrease test time, enhance safety, and determines performance. The Keysight E36731A battery emulator and profiler does all these things and more. Another way to answer the question is that an emulator is bi-directional, while a DC power supply (voltage regulation) and an Electronic load (current regulation) are uni-directional. This is only a starter. Please scroll down to read the rest of the documentation on this product.
Design for Better Battery Life - The Keysight E36731A battery emulator and profiler is an integrated electronic load and power supply developed to use with Keysight PathWave BenchVue battery emulation software. An emulated battery gives you a known good reference for testing at any charge level. Quickly assess the effect of design or software changes on battery life by emulating any battery charge state. Leverage emulation and precise current drain analysis to achieve longer battery life or to reduce the size of your device.
Validate and Extend Battery Life - Analyzing the current drain and conducting run-down battery tests of your designs pose several difficulties. The manual process of charging and discharging a battery is time-consuming, and it's crucial to test it at different charge levels as battery characteristics vary. Furthermore, battery parameters and charge levels must be identical when comparing test results. Achieving this is very challenging with physical batteries. Additionally, it is difficult to determine how long a device will last on a single charge, and often battery life claims do not match reality. Keysight designed the E36731A battery emulator and profiler and BV9211B advanced battery test and emulation software to solve these challenges. This demo video guides you through the process of using the solution to verify and prolong the battery run time of your device.
Enhance IoT Battery Performance using Emulation Software - For IoT-based infrastructure and consumer electronic IoT devices, designers must understand power consumption patterns and whether devices meet battery life requirements. In this white paper, discover how to overcome these power challenges using the E36731A battery emulator and profiler and PathWave BenchVue battery emulation software. You will learn how to quickly gain critical insights into battery drain to optimize your design to extend and accurately predict battery run time.
Product Variants
  • E36731A---this is the variant for this roadtest
  • E36731ABV
Features
  • Generate accurate battery profiles using the simulated current drain of a device.
  • Instantly emulate any battery charge state and display real-time current drain data.
  • Achieve accurate battery run-down tests by emulating your device’s current drain.
  • Estimate battery aging effects to predict device performance throughout its lifetime.
  • Streamline your workflow with an integrated power supply and an electronic load.
  • Creates a battery model for any battery type.
  • Power up to 200W, 30V, and 20A.
Documentation
Kit Contents
Battery emulator and profiler, AC power cord (based on destination country), Certificate of calibration, One detachable front output connector, One rear output connector, One rear remote sense connector, One digital IO connector.
RoadTest Goals
Working with the documentation, open the box and test the out of the box experience. Show us what you discovered through text, images, videos, and/or any other media, so the reader understands what is involved in using the product.
Important Dates
Begin enrollment:  August 9, 2023
End enrollment:  Sept , 2023
Select roadtesters: Oct 17 2023
Ship unit:  Oct 24 2023
Begin Roadtesting:  Oct  31 2023
Element14 follow up: Dec 1 2023
Post Reviews by:  Jan 22 2024
More About Keysight Technologies
At Keysight, we inspire and empower innovators to bring world-changing technologies to life. As an S&P 500 company, we're delivering market-leading design, emulation, and test solutions to help engineers develop and deploy faster, with less risk, throughout the entire product lifecycle. We're a global innovation partner enabling customers in communications, industrial automation, aerospace and defense, automotive, semiconductor, and general electronics markets to accelerate innovation to connect and secure the world.
Learn more about Keysight Technologies on their Community Page!
Keysight Products
Terms and Conditions
Please reference the attached file below.
RoadTest Reviews
Comment List
  • Does the kit include the BV9210B software license (PathWave BenchVue Advanced Battery Test and Emulation Software)?
  • Answering my own question. The Roadtest states:
    • E36731ABV
    The E36731ABV is a bundle of the instrument and the BV9210B software license (PathWave BenchVue Advanced Battery Test and Emulation Software). So, it looks like there is no provide license.
  • I suspect they will want you to use the trial - 7 days by default, extended to 30 days with submitting your details:
  • Good point. I just sent an email to my contact at Keysight.
    Randall
  • Well, it looks like even the E36731ABV comes only with a time limited (12 month) PathWave BenchVue advanced battery test and emulation software license. After that the desktop software licence seems to cost around $800+ per year. Unamused Does not seem to be any perpetual software license options available.
    Looking at the user manual of the E36731A, the DC Power Supply and Electronic Load capabilities look to be completely controllable from the front panel of the instrument, and via SCPI over LAN / LXI and USB. No software licences are needed to use these.
    The Battery Emulation functionality is implemented in the BenchVue software. Given the high cost, I think the BenchVue software licence is not really an option for hobby use. I would rather implement basic battery emulation myself as an (open source) Python app / library. Sunglasses
