Become a Tester of the PSOC™ 6 AI Evaluation Kit enabled with DEEPCRAFT™ AI/ML software solutions
View table of contents
Are you looking to incorporate machine learning (ML) into your designs? Are you looking for a way to collect data, and then locally process that data at the edge? Then this is your chance to enroll to be a product tester of Infineon’s PSOCTm 6 AI Evaluation Kit enabled with DEEPCRAFTTm Studio (formerly Imagimob Studio).
April 8th Webinar: Exploring Edge AI Use Cases leveraging the Infineon PSOC 6 AI Evaluation Kit (AMER) Tuesday, April 08, 2025
Description:
PSoC
What is the “Infineon PSOCTm 6 AI Kit enabled with DEEPCRAFTTm Studio (formerly Imagimob Studio) RoadTest?
In this roadtest, the tester will test and experiment with Infineon's PSOCTm 6 AI Eval Kit, a machine learning development platform designed with sensor data collection and ML models in mind.
To fully test the Infineon PSOCTm 6 AI Kit enabled with DEEPCRAFT Studio (formerly Imagimob Studio) roadtesters will also receive or have access to the following:
  • PSOCTm 6 AI Evaluation Kit (CY8CKIT-062S2-AI // Buy Now  )
  • ModusToolboxTm software v3.2 or later
  • DEEPCRAFT Studio (formerly Imagimob Studio) - Development Platform for AI / Machine Learning on Edge Devices
  • DEEPCRAFT Ready Models (formerly Imagimob Ready Models) - production-ready AI / Machine Learning models
  • Avnet IoTConnect for Infineon's ModusToolboxTm and framework
What software and tools do you need for this roadtest?
  • Code examples for this kit require ModusToolboxTm software version 3.1 or later. This is available on the ModusToolboxTm software webpage.
  • DEEPCRAFT Studio (formerly Imagimob Studio) software version 4.4 or later. This is available on the DEEPCRAFT Studio (formerly Imagimob Studio) webpage.
RoadTester Instructions:
For each of these tests, show the reader of this review what you discovered utilizing text, images, videos, and/or any other media, so the reader understands what is involved in using the product.
  • Test the out of box experience:
    • Working with the documentation, open the box and test the out of the box experience of the Infineon PSOCTm 6 AI Eval Kit.
    • Explore the board, and then follow the “CY8CKIT-062S2-AI Getting Started Guide” and use DEEPCRAFT Studio (formerly Imagimob Studio) and the onboard sensors to collect data in preparation for creating your model. (You are not required to create a model.)
    • Flash one of the DEEPCRAFT Ready Models (formerly Imagimob Ready Models).
  • Develop code using ModusToolbox:
    • Explore how to develop code with the PSOCTm 6 AI kit
    • Explore available code examples (from “hello world” to connectivity and ML examples, and more)
    • Debug development code directly with the KitProg3 on-board debugger
  • (Optional) Learn ML models on the PSOC 6 can be easily connected to the cloud with Avnet’s IoTConnect:
    • By following a step-by-step guide on GitHub, you can create an interactive dashboard leveraging the Imagimob Sound Classification model without any software development! To discover how this experience was made, check out the IoTConnect libraries in ModusToolbox and start using them today with Project Creator!
    • If applicable, your roadtest can include the use of Avnet’s IoTConnect software by either:
      • Using IoTConnect libraries within ModusToolbox
      • Or using a pre-build binary made available through GitHub from Avnet
    • Test out the IoTConnect dashboards for easy visualization of the Imagimob ready models.
RoadTest Components:
What is the PSOCTm 6 Artificial Intelligence Evaluation Kit?
The PSOCTm 6 AI Evaluation Kit is a cost-effective, small form-factor, hardware platform focused on Machine Learning (ML). It enables customers to evaluate Infineon’s ML platform DEEPCRAFT Studio (formerly Imagimob Studio), as well as ready-to-deploy ML models, and other software products. The board is designed for easy prototyping and lets customers collect real-life data to build ML products fast.
 The PSOCTm 6 AI Evaluation Board has the following features:
What is ModusToolboxTm?
ModusToolboxTm software is a set of tools that enable you to integrate Infineon devices into your existing development methodology. If you are new to PSOCTm 6 MCU, and ModusToolboxTm IDE, see the application note AN228571 - Getting Started with PSOCTm 6 MCU on ModusToolboxTm software (see Documentation section on this page) to help you familiarize with the PSOCTm 6 MCU and help you create your own design using the ModusToolboxTm IDE. There are various code examples to evaluate the PSOCTm 6 AI Evaluation Board, which familiarizes you with PSOCTm 6 MCU and creates your own design. These examples can be accessed through ModusToolboxTm.
 What is DEEPCRAFT Studio (formerly Imagimob Studio)?
DEEPCRAFT Studio (formerly Imagimob Studio) is an end-to-end platform for developing AI / Machine Learning models for the edge. The platform is designed to support users in creating robust and high quality models that are ready for deployment in commercial products.
 What are DEEPCRAFT Ready Models (formerly Imagimob Ready Models)?
DEEPCRAFT Ready Models (formerly Imagimob Ready Models) are production-ready AI / Machine Learning models that are ready to be added to any edge device. These models save time, cost, and resources needed to create collect, validate, and label data, as well as to train custom AI / Machine Learning models on that data. Some available Ready Models cover the following applications:
  • DEEPCRAFT Ready Model for Baby Cry Detection
  • DEEPCRAFT Ready Model for Gesture Detection
  • DEEPCRAFT Ready Model for Factory Alarm & Siren Detection
  • DEEPCRAFT Ready Model for Snoring Detection
What is IOTConnect?
Infineon partner Avnet offers IoTConnect, a comprehensive solution accelerator software that facilitates IoT device connectivity, real-time monitoring, and advanced analytics. It offers seamless device integration, robust security, and easy and clear methods to gain valuable insights for businesses to optimize operations and drive innovation.
Roadtester Poll
Documentation:
PSoCTm 6 Artificial Intelligence Evaluation Kit
ModusToolboxTm
IOTConnect
Dates
Begin enrollment
August 30 2024
End enrollment
September 30 2024
Select RoadTesters
Feb 5 2025
Ship unit
Mar 5 2025
Begin RoadTesting
Mar 10 2025
element14 followup
Apr 10 2025
Post reviews by
May 10 2025
RoadTester Deadlines
  • skruglewicz- deadline June 21 2025
  • battlecoder - deadline June 21 2025
  • fyaocn - deadline May 24 2025
About the Sponsor:
Infineon Technologies AG is a global semiconductor leader in power systems and IoT.Infineon Infineon drives decarbonization and digitalization with its products and solutions. The company has around 58,600 employees worldwide and generated revenue of about €16.3 billion in the 2023 fiscal year (ending 30 September). For more information, go here.
Terms and Conditions
See the attached file below for the terms and conditions
RoadTest Reviews
Comment List
