RoadTest: MSP-EXP430FR5739
Author: gordonmx
What other parts do you consider comparable to this product?: LaunchPad
What were the biggest problems encountered?: USB cable was too short.
REVIEWER NOTE: In this column, the MSP-EX430FR5739 Experimenter Board has been reviewed by many able bodied individuals (i.e. Brian Onn, DAB, dweb98, icserny, etc.). Like everyone else, I received my kit quickly and with all the same materials. I loaded all the software, ran through all the examples and came to the same conclusions as many of you have. If you are interested in these details, please check out the other reviews, but for me, let's takes another twist.
(Side Note: My review was delay by a very bad case of the "System Restore" PC virus. A very bad virus!)
Once again I'm given the privilege and opportunity to evaluate and review an evaluation kit (EVK) through Element 14. The terms development, evaluation, experimenter or demo are often attached to the word tool, board or kit very loosely. Before evaluating the MSP-EX430FR5739 Experimenter Board, highlighting TI's first embedded ferro-electric random access memory (FRAM) based MCU, we must first ask ourselves what we are reviewing.
Digressing a moment, the following is an attempt to define what these name mean. All kits by nature are evaluation systems, used to highlight one or more of a manufacturer's products. For the most part, terms in the title like board, tool or kit, may be used interchangeably. For this discussion I will use "kit".
Some kits cross the line in some areas. A demo board may include some programming functionality through a USB port, but this does not make it a development kit.
So what does this mean for the MSP-EX430FR5739 Experimenter Board?
Let's check TI's claims from their website for the kit:
For the most part, this is true, but no different than for the original MSP430 MCU through the Launchpad platform since most memory functionality is transparent. From this point, the MSP-EX430FR5739 is what it claims to be, an experimenter kit. Although many of the pins are available, some I/O pins are tied up by peripheral devices (i.e. accelerometer, thermister and LED display).
This is stretching the functionality a little too much.
This is where things get a little more border line, since we don't have any hardware to compare these claims. The board does make it easy to measure the current draw to compare against similar boards with standard memory, but memory speed and endurance are hard to compare. In this area, the kit little more than a demo board for the FRAM -based MCU. I'm not as familiar with the MSP430 as I should be, but if there were a plug compatible standard memory part and a socket to exchange them, a truer comparison could be made.
Some positive features include:
- Code Composer Studio and
- IAR Embedded Workbench Kickstart.
Some negative features include:
Summary -
Good value for an experimenter board, but may be too restrictive for development.
Regards,
Gordon Margulieux
Salem, OR USA
gordonmx
Cancel
Up
0
Down
More
Cancel
Comment-
gordonmx
Cancel
Up
0
Down
More
Cancel
