Review of Atmel SAM-4S Xplained Evaluation Kit
Table of contents
RoadTest: Atmel SAM-4S Xplained Evaluation Kit
Author: jessej89
What were the biggest problems encountered?: The biggest problem is just getting use to the board, but once you get the hang of it, it becomes simple and easy.
This is a great powerful board, I got my board on valentines day and I used an example code for my review I used the temperature example code, where it read the room temperature in celsius from the built in sensor on the board and then u can do whatever you like with the reading. Here is a video i recorded. Over all I give this 10 out of 10, it's great for everyone from engineers to hobbyist.
  • Good start Jesse,
    Did you have anything to compare the accuracy of the measurement to?
    Did you try hot versus cold? Items like that make the road test interesting.
    Also, I cannot access your video.
    Steve
  • I just measure room temperature in celsius, and I should of did a compare test to see if the accuracy was corrcect that would make it more interesting. Sorry about the video I thought it would work but here is the video again and next review I do I will make it much more interesting.
  • Jesse,
    The Video is working now. I guess Element14 had to put their blessing and mark on it.
    Keep up the good work. Experiment with it. Make the Road Test fun for you.
    By the way, I received my kit today.
    I like the way the kit was packaged in a foam lined re-sealable plastic case complete with a heat-sealed anti-static bag with a tamperproof seal. All his placed in a factory box and Newark placed the package in their shipping box with packing.
    Guaranteeing this side of a truck running over the box, no shipping  damage incurred.
    Nice touch.
    Steve
  • Jesse,
    Nice touch.
    Steve
