RoadTest: Texas Instruments DLP® LightCrafter™
Author: bigchin
What other parts do you consider comparable to this product?: in house development
What were the biggest problems encountered?: 1. The color is not uniform. Even with adjustment and cannot get the uniform colors to match color chart. 2. Light distance is not far enough for my application. 3. The delay time/jitter is too long for high-speed application. It is good for simple low speed video display.
I believe this module is a great one for those who want to display simple video. It is handy and does not require additional cooling. However, the module that I received had several drqwbacks. the first is red color uniformity. I had tried numerous times to calibrate and still not come out matching with my color chart. The second one is the delay time or jitter issue. this may not be an issue for people to do 3D display. However, it makes it unsuitable for sensitve application like PLL. the fhird issue is the display distant. for my application, it is not bright enough.
