AVNET MicroZed SOM 7Z010 + Carrier Card - Review
Table of contents
RoadTest: AVNET MicroZed SOM 7Z010 + Carrier Card
Author: vmate
What other parts do you consider comparable to this product?: Digilent's various development boards, PYNQ
What were the biggest problems encountered?: Lack of documentation for beginners
The MicroZed SOM 7010 is a module using a Zynq 7010 SoC with 1GB of DDR3 RAM, providing 108 IO pins, 1Gbit Ethernet, and USB2.0.
The Arduino Carrier Card provides 2 PMOD connectors, one connected to the PL, the other connected to the PS. All of the Arduino pins are connected to the PL.
PS vs PL
The PS(Processing System) is a dual core ARM CPU in the case of this board, which can run C/C++ code, an RTOS, or Linux.
The PL(Programmable Logic) is the FPGA part of the chip.
These two parts can be connected together, for example, a hardware SPI controller can be created in the PL and connected to the PS, in case the 2 built-in SPI controllers aren’t enough.
There are separate pins on the Zynq that are connected to the PL, and another set of pins that are connected to the PS. The PL pins however can be used with the PS, by using AXI GPIO IP.
Setting up Vivado
After installing Vivado, the board definition files need to be installed as well. Unfortunately, the MicroZed page has an outdated version of this file available. After downloading the latest version from GitHub, the microzed_7010 folder needs to be copied to
<install_location>\Vivado\<version>\data\boards\board_files
Defining hardware in Vivado
{gallery} Creating Vivado project
Creating Vivado Project: Create new project
Creating Vivado Project: New project start screen
Creating Vivado Project: Name and location of new project
Creating Vivado Project: Set project type
Creating Vivado Project: Select board preset
Creating Vivado Project: New project summary
Next, add the constraints file to the project.
Unfortunately, Avnet doesn't provide a "generic" XDC file for the Arduino Carrier Card, so I made one:
set_property -dict { PACKAGE_PIN Y16    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D15}];
set_property -dict { PACKAGE_PIN Y17    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D14}];
set_property -dict { PACKAGE_PIN W14    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D13}];
set_property -dict { PACKAGE_PIN Y14    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D12}];
set_property -dict { PACKAGE_PIN T16    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D11}];
set_property -dict { PACKAGE_PIN U17    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D10}];
set_property -dict { PACKAGE_PIN V15    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D9}];
set_property -dict { PACKAGE_PIN W15    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D8}];
set_property -dict { PACKAGE_PIN N18    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D7}];
set_property -dict { PACKAGE_PIN P19    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D6}];
set_property -dict { PACKAGE_PIN N20    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D5}];
set_property -dict { PACKAGE_PIN P20    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D4}];
set_property -dict { PACKAGE_PIN T20    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D3}];
set_property -dict { PACKAGE_PIN U20    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D2}];
set_property -dict { PACKAGE_PIN W20    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D1}];
set_property -dict { PACKAGE_PIN V20    IOSTANDARD LVCMOS33 } [get_ports {ARDUINO_D0}];
set_property -dict { PACKAGE_PIN G17    IOSTANDARD LVCMOS33 } [get_ports {PMOD_1}];
set_property -dict { PACKAGE_PIN G18    IOSTANDARD LVCMOS33 } [get_ports {PMOD_2}];
set_property -dict { PACKAGE_PIN F19    IOSTANDARD LVCMOS33 } [get_ports {PMOD_3}];
set_property -dict { PACKAGE_PIN F20    IOSTANDARD LVCMOS33 } [get_ports {PMOD_4}];
set_property -dict { PACKAGE_PIN N15    IOSTANDARD LVCMOS33 } [get_ports {PMOD_7}];
set_property -dict { PACKAGE_PIN N16    IOSTANDARD LVCMOS33 } [get_ports {PMOD_8}];
set_property -dict { PACKAGE_PIN L14    IOSTANDARD LVCMOS33 } [get_ports {PMOD_9}];
set_property -dict { PACKAGE_PIN L15    IOSTANDARD LVCMOS33 } [get_ports {PMOD_10}];
Import the constraints file to the Vivado project
{gallery} Importing Constraints
Importing Constraints: Add sources button
Importing Constraints: Select source type
Importing Constraints: Choose constraints file
Importing Constraints: Finalizing
Next, create a block design, add the ZYNQ7 Processing System, and generate an HDL wrapper
{gallery} ZYNQ Processing System
ZYNQ Processing System: Creating Block Design
ZYNQ Processing System: Block Design name and location
ZYNQ Processing System: Adding IP
ZYNQ Processing System: Add ZYNQ7 Processing System IP
ZYNQ Processing System: Run Block Automation
ZYNQ Processing System: Block Automation settings
ZYNQ Processing System: Creating HDL Wrapper
ZYNQ Processing System: HDL Wrapper settings
After creating the wrapper, generate a bitstream and export hardware
{gallery} Exporting Hardware
Exporting Hardware: Generate Bitstream
Exporting Hardware: Bitstream generation settings
Exporting Hardware: Completion of bitstream generation
Exporting Hardware: Export Hardware button
Exporting Hardware: Export Hardware dialog
Exporting Hardware: Export settings
Exporting Hardware: Save location and name
Exporting Hardware: Finalizing
Create Vitis Application Project
{gallery} Creating Vitis Application Project
Creating Vitis Application Project: Start
Creating Vitis Application Project: Import platform exported from Vivado
Creating Vitis Application Project: Name project
Creating Vitis Application Project: Create domain
Creating Vitis Application Project: Finalize
Blink User LED (Working with PS outputs)
The User LED on the MicroZed is connected to the PS. The following code will blink the LED with a 1 second delay.
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xgpiops.h"
#include "xstatus.h"
#include "xplatform_info.h"
#include "sleep.h"
XGpioPs Gpio;
int main()
    init_platform();
    XGpioPs_Config *GPIOConfigPtr;
    GPIOConfigPtr = XGpioPs_LookupConfig(XPAR_PS7_GPIO_0_DEVICE_ID);
    XGpioPs_CfgInitialize(&Gpio, GPIOConfigPtr, GPIOConfigPtr->BaseAddr);
    XGpioPs_SetDirectionPin(&Gpio, 47, 1);
    XGpioPs_SetOutputEnablePin(&Gpio, 47, 1);
    while(1) {
    XGpioPs_WritePin(&Gpio, 47, 0);
    sleep(1);
    XGpioPs_WritePin(&Gpio, 47, 1);
    sleep(1);
    cleanup_platform();
    return 0;
Control User LED with User Button (Working with PS inputs)
The following code reads the User Button state and controls the User LED accordingly.
#include <stdio.h>
#include "sleep.h"
XGpioPs Gpio;
int main()
    init_platform();
    XGpioPs_SetDirectionPin(&Gpio, 51, 0);
    while(1) {
    int state = XGpioPs_ReadPin(&Gpio, 51);
    XGpioPs_WritePin(&Gpio, 47, state);
    cleanup_platform();
    return 0;
Connecting the PS and PL - Creating a NAND gate
Additional GPIO "controllers" can be created in the FPGA part of the Zynq, which also allows us to connect custom HDL modules to the input/output of those GPIO controllers.
In this example, we'll create a NAND gate in the FPGA, the output of which is connected to an AXI GPIO IP, which is also implemented in the FPGA, which is then read by the PS, that controls the User LED according to the output of the NAND gate.
First, create a new Verilog module that implements a NAND gate
{gallery} Creating Verilog NAND gate
Creating Verilog module: Add Sources
Creating Verilog module: Select source type
Creating Verilog module: Create new file
Creating Verilog module: New file properties
Creating Verilog module: Finish adding new source
Creating Verilog module: Specify I/O Ports
Creating Verilog module: Create NAND gate
Then, add the NAND gate module to the Block Diagram
Enable the AXI master interface in the Zynq Processing System by double clicking on it, and selecting the appropriate option shown below.
Add the AXI GPIO IP to the block diagram
Run Connection Automation for AXI port on the AXI GPIO IP
Configure AXI GPIO as a single input
Connect NAND gate output to AXI GPIO input
Connect inputs on NAND gate to physical pins on the FPGA
Rename external connection to a pin name from the constraints(.xdc) file.
Repeat for input "b"
Completed block diagram
Generate the bitstream and export hardware, then launch Vitis and create new hardware project as shown previously.
Processing System code for reading NAND gate output through AXI GPIO, and controlling User LED accordingly:
#include <stdio.h>
#include "sleep.h"
#include "xgpio.h"
#include "xparameters.h"
XGpioPs Gpio;
XGpio FPGA_Gpio;
int main()
    init_platform();
    XGpio_Initialize($FPGA_Gpio, XPAR_AXO_GPIO_0_DEVICE_ID);
    XGpio_SetDataDirection($FPGA_Gpio, 1, 0);
    while(1) {
    int state = XGpio_DiscreteRead(&FPGA_Gpio, 1);
    cleanup_platform();
    return 0;
Conclusion
The MicroZed is a very capable board with plenty of documentation, however there is some very basic information missing for people who haven't worked with a Xilinx FPGA/Zynq SoC before. The first thing I wanted to do with this board was make a NOT gate in the FPGA using the User Button and User LED, but as it turned out after doing some research, the User LED and User Button are connected to the MIO pins, which can only be controlled from the PS. Basic information like this could be very useful for a beginner, just like providing a generic constraints file for the Arduino Carrier Card. Otherwise, the documentation is well made, and there are plenty of example projects available to download.
Having more PMOD connectors on the Arduino Carrier Card would be useful, even if it shared pins with the Arduino headers. The current configuration of one PS PMOD and one PL PMOD makes it inconvenient to use PMODs that require two connectors, requiring the use of jumper cables to interface with the Arduino headers as well for the second PMOD connector.
A PL PMOD in addition to the PS PMOD on the MicroZed itself would be favorable as well.
Parents Comment Children
