Wolfson Audio Card for Use with Raspberry Pi - Review
Table of contents
RoadTest: Wolfson Audio Card for Use with Raspberry Pi
Author: malakai
What were the biggest problems encountered?: Incorporating the necessary files into Raspbian by default is still being worked on.
Full Run
Short Run
Grab the Jasper image from their website
Jasper | Documentation
Copy the image to the SD Card boot Pi. Run the configuration utility.
sudo raspi-config
expand rootfs, set localization, keyboard, and time.
reboot the Pi then update Raspbian
sudo apt-get update && sudo apt-get upgrade -y
Get Ragnar Jensen's kernel originally posted setup Re: Re: Wolfson modified Noobs raspbian zipped img  Cannot unzip new download
File name is kernel_3_10_25_wolfson.tgz
Size is 17MB
https://drive.google.com/file/d/0BzIaxMH3N5O1RnJfcGVpdmY1T1E/edit?usp=sharing
md5sum dec8d63b3c42846e54082c7c6ff1834f
To install:
Become root: sudo -s
Go to root directory: cd /
Untar the archive: tar xvzf /path/to/where/you/saved/kernel_3_10_25_wolfson.tgz
Add the line
  kernel=kernel_wolfson.img
to the file /boot/config.txt
·         Reboot
If it doesn't work, you can revert to your original kernel by just removing the "kernel=kernel_wolfson.img" line from/boot/config.txt
  • Grab Wolfson img
wget http://www.element14.com/community/servlet/JiveServlet/download/104303-128960/wolfson_drivers.tar.gz
Extract the patch software into the home directory
tar -zxvf wolfson_drivers.tar.gz
    A.  Configuring the Jasper Client
Install Jasper Client
In the home directory of your Pi, clone the Jasper source code:
git clone https://github.com/jasperproject/jasper-client.git jasper
§  Jasper requires various Python libraries that we can install in one line with:
sudo pip install –upgrade setuptools
sudo pip install -r jasper/client/requirements.txt
Run crontab -e, then add the following line, if it’s not there already:
@reboot /home/pi/jasper/boot/boot.sh;
Set permissions inside the home directory:
sudo chmod 777 -R *
I run the script anyways as it doesn't always go right on reboot.
sudo reboot
Restart your Raspberry Pi. Doing so will run boot.py, which generates the languagemodel.lm file in the client/ folder.
Using Ragnar Jensen’s .asoundrc file is the key to getting it to work
Backup the existing file
cp ~/.asoundrc .asound.backup
rm ~/.asoundrc
sudo nano ~/.asoundrc
Paste the contents of the modified ./asoundrc file listed below.
Getting Jasper to play requires that you can play a wav file using aplay with no arguments. Once that works, you want to remove the aplay hardware references(-D hw:x,x) in /boot/boot.py and /client/mic.py
Try this file:
aplay /home/pi/jasper/static/audio/jasper.wav
If you get it to play you have setup your system correctly and are good to go.
You may need to test the Wolfson files for the correct connection:
./asoundrc file contents modifications made by Ragnar Jensen
# Use libsamplerate instead of internal resampler.
# You might have to: sudo apt-get install libasound2-plugins
# Or just comment out the next line if the internal one is good enough for your needs.
# defaults.pcm.rate_converter "samplerate"
# Wolfson Audio Card for Raspberry Pi
pcm.wolfson_pi_soundcard {
    type hw
    card sndrpiwsp
    device 0
# Create a Master volume control
pcm.softvol {
    type            softvol
    slave {
        pcm         "pduplex"
    control {
        name        "Master"
        card        0
pcm.!default  {
    type           asym
    playback.pcm   "plug:softvol"
    capture.pcm    "pduplex"
# Mixing and resampling goodness :-)
# Several clients can record and play back simultaneously.
# The dmix and dsnoop plugins operate at 48kHz by default, i.e. the sound card will be kept at 48kHz at all times.
# All playback streams are converted to 2 channels/48kHz/16bit.
# All recording streams are converted from the card's 2 channels/48kHz/16bit
# to the requested number of channels, sample rate and bit depth.
# We define one pcm device called "playmixer" for playback.
pcm.playmixer {
        ipc_key 140324  # Any number will do, as long as it's unique in the system.
        ipc_key_add_uid true
        type dmix
        slave.pcm "wolfson_pi_soundcard"
# Define another one called "recmixer" for capture.
# The sound card will run at 48kHz and input is resampled to the requested rate.
pcm.recmixer {
        ipc_key 140325
        type dsnoop
# Define a duplex device, with both in- and outputs.
pcm.duplex {
        type asym
        playback.pcm "playmixer"
        capture.pcm "recmixer"
# Add a "plug" plugin for the above "duplex" device.
# This is where all the converting takes place.
# Sample rate, number of channels, bit depth.
# By the way, who thought that "plug" was a good name for a plugin?
# Use this device for all your playback and recording resampling needs.
pcm.pduplex {
        type plug
        slave.pcm "duplex"
# A ctl device to keep xmms happy
ctl.pduplex {
        type hw
        card 0
# A DSP to keep the alsa-oss layer happy:
pcm.dsp0 {
        type plug
        slave.pcm "duplex"
ctl.mixer0 {
        type hw
        card 0
Parents Comment Children
