RoadTest: Multicomp Pro MP750511 Arbitrary Waveform Generator
Author: pandoramc
Evaluation Type: Workshop Tools
What other parts do you consider comparable to this product?: Keysight 33612A
What were the biggest problems encountered?: The software has not direct compatibility with CSV files
The first stage is the Unboxing process, this was a very interesting instrument and I though about made more videos.
The proposal for the videos posted here are the following:
after these videos, I will post more in this blog or others. Thanks Element 14 Community.
Now, I show the usage of the MP750511 to test an analog integrator; remember, this circuit is based on the low pass filter, using a signal with frecuency greater or equal than the cutoff frecuency.
Now, what about a digital programmable version? The video below shows this scenario.
Lastly, I recommend use with calm the instrument, if you force extra processing when the signal is generated cause the instrument get stuck.
